Flywheel bolts for S197 ?
Are these the correct bolts for my flywheel? I'm replacing the clutch and flywheel and I want to replace the flyhwheel bolts with ARP..
http://www.summitracing.com/parts/ARP-254-2801/
Nope, it did not come with any. I know the flywheel is like 60 ft lbs and the pressure plate bolts are like 25 ft lbs.
I just have not been able to find facts that these are the correct flywheel bolts.
This is what I used, but I bought them through Tousley Ford I believe, as I wasn't sure if my new flywheel would come with them or not. It did, but I used the factory bolts anyways.
http://www.summitracing.com/parts/FM...79-B/?rtype=10
I didn't see a reason to go ARP for them. I've never come across anyone breaking a flywheel bolt. I think the clutch would go before that would happen.
Upon further inspection, those ARP bolts have a different thread pitch than the 4.6l bolts you need. They won't work.
Ok, thanks much! I found comments that the OEM's can be reused, I just always reaplced them.
junior04
09-28-2015 10:53 AM
