Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Why is My Key Stuck in the Ignition?
Guide to diagnose trouble and recommended solutions.
Key stuck in ignition
And don't bother looking for a button near your shifter. It doesnt exist in a manual.
Lastly, I don't remember what years Ford did this, but some Mustangs had a key release near the ignition switch. You had to press that small lever forwards or pull backwards gently on it to put the ignition switch fully in the off position. Until your ignition is in the off position you can't remove the key. Maybe look for that near your ignition switch. It was designed to be used with one hand on the right side of the steering column. Pretty small lever too that you'd use one finger for on your right hand.
my wife's chrysler 300 wouldn't come out of park, because a piece in the shifter had broken off. After taking the shifter apart and putting it back together, I then couldn't get the key out of the ignition. There is a safety device on the chrysler that pulls a cable when the car is placed in park, which allows you to remove the key. If they cable is to tight, then the key won't come out. I had to adjust the cable and the key popped right out. Also disconnecting the battery allowed the key to come out, because the solenoid that pulls the cable lost power.
At least you can get yours out of park and drive home, she couldn't.
similar problem
So i've had my 2014 V6 standard transmission about a year now and no problems with it up until now. Recently inspected too. Yesterday the car worked flawlessly and no issues. Head to the gym today and turn off the car and key only partially comes out (~1/4 inch). I've done just about every method of turning the wheel, brake and reverse things that have helped other people but to no avail. The key still goes all the way in and can start the car. Can go all the way to off as well and start to come out, but then stops. Drove all the way home and shifted between each gear just to make sure and still no luck when i got home. Anyone have any ideas?
lincolnshibuya
12-08-2015 04:37 PM
bradleyb
11-27-2015 07:50 PM
logan409
09-26-2015 07:43 PM
