Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Why is My Key Stuck in the Ignition?
Guide to diagnose trouble and recommended solutions.
Key stuck in ignition
Ok, I have found this to be a pretty common problem with the stock automatic shifter. This is how you get the keys out:
On the right side of the shifter bezel you see a small flat button. Push that button down as far as it goes and at the same time turn your key. If that does not work do the same thing again but this time push forward on the shifter. This will let you get your key out.
Here is a pic of the button.
If that still does not work PM me and I will give you my cell # and I'll walk you threw it on the phone.
I've had a similar problem with putting the car into drive/reverse... Almost like the shifter likes to hang in the dead space between the gears.
Now I just wiggle it to make sure it's engaged before I do anything. These shifters were made with appallingly bad tolerances.
Is your steering wheel turned hard or to the turn stops? I've seen where a key wouldn't come out of the cylinder until steering wheel pressure against the steering lock mechanism was relieved.
I have a 2003 Mustang that I just bought last weekend. WE got it back from a repair shop that we trust and he assured me that there are no problems. when i parked my car in my driveway and turned the car off, it wouldnt let me remove the key. i cant take it out or turn the car on. i can still use the clutch and shift gears but cant get the keys out. brake pedal is locked up and so is the steering wheel, but i can turn the steering wheel a little to the left. i was thinking about releasing the e-brake and letting it roll down my driveway in neutral to see if it might help but i didnt think it would be to good of an idea as my brake pedal is locked and so is my steering wheel. any ideas on what i should do? 2003 mustang (base model) 99 k miles, 5 speed man. trans
thanks
thanks
thanks
thanks
When I've had this happen in a manual, everytime it was because of being close to the steering lock. Turn the wheel harder in both directions while trying to make sure you're definitely in the off position then remove your key.
