Sponsored by:
Sponsored by:
smart junction box
Old 01-17-2012, 01:09 PM
jtfrog
jtfrog's Avatar
Default smart junction box
how do I remove the smart junction box on 07 gt
jtfrog is offline
Old 01-17-2012, 01:16 PM
Derf00
Gentleman's Relish
Derf00's Avatar
http://iihs.net/fsm/?dir=41
That would be the best place for reference. Might take a little bit of digging to find the right section though.
Derf00 is offline
Old 01-17-2012, 01:24 PM
jtfrog
jtfrog's Avatar
thanks got it off , having a hard time putting in my trunk release switch
jtfrog is offline
Old 01-20-2012, 09:36 PM
Exley
Exley's Avatar
Its pretty straight forward, please bear with me though because I took mine out a while ago when I installed some foot well lights in my car.
1. Best access I found is to lay on your side on the passenger side of the car and look inside.
2. It's in the access panel on the far right side, where your right foot would be if you were sitting in the passenger side.
3. take off the fuse/access panel.
4. This is the part I'm a little fuzzy on. I believe you remove the passenger side scuff panel and then you should be able to pop off the trim panel that surrounds the SJB.
5. after that there is a long threaded bolt that holds it to the side of the car. you will need to remove this with a deep well socket (10 mm?)
6. then you slide the SJB off the bolt by leaning it toward the roof of the car and kinda pull down. the SJB is kinda hooked to the body of the car.
again I'm doing this from memory so it might not be exact
you get a quick but pretty good look at it in this video
http://www.youtube.com/watch?v=qcuwj39-HsQ
lol didn't see that you already got it off. Hopefully this helps someone
Exley is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
mapitts
05-15-2016 02:57 AM
daltron
04-28-2016 08:10 PM
daytooday
09-20-2015 10:55 AM
Quick Reply: smart junction box
