Im as low as te damn coils will go in te rear and don't rub. Pinion angle really doesn't cause a problem. You can slap the coils on an go no problems. It isn't ideal but fine none te less
it might not be a problem for your car since it's a 2009. He has a 2005, and research on other forums, most problems are in those 05-earlier 07 models.
Couldn't I just put a spacer between the driveshaft and the diff?
