dealer overfilled engine oil
6 liters is usually good for the 4.6 which is just about 6.5 qts, i just throw in 7 just bc i dont see a difference in the stick and half a quart isnt going to hurt anything and your going to somehow burn/lose some oil down the line.
Anything between 6-7 quarts is safe, and I'd also fill to the upper end (top of scale). A full sump means quicker oil pressure on cold starts, and a (slightly) cooler running engine.
The least experienced guy there is the one doing oil changes. Do you really want to trust that guy? It's so simple to change your own oil......do it yourself and have peace of mind. I did my oil and trans fluid this weekend. I know it was done properly.
OP, were you charged more cause you went over 6qts? When I did oil changes at a certain national chain, they wanted to push the additional fee of over 6qts so they wanted us to put 6.3-6.4 on the workorder. Just food for thought.
[quote=oldlugs;7838531A full sump means quicker oil pressure on cold starts, and a (slightly) cooler running engine.[/quote]
It also gives you just a little extra protection against uncovering the pickup in a sustained high-lateral-g corner.
Norm
Norm
No because i brought in my own oil! i had 7 quarts in the box and he put in 6.75 quarts when the manual says 6 quarts
And if you knew the manual said 6 qts why would you give the tech 7qts?! Interesting and i'm still gonna say 7 qts works out just fine for my 2010 gt
Thats strange ... Why would you bring in your own oil and pay the dealer to change it. I know if a customer comes to us and has there own oil (which is rare) we still charge him full price as if we put our bulk motorcraft synthetic blend oil in either way because its one set price.
inyadreems
08-21-2015 09:10 AM
2012, 50, bring, change, dealer, dealership, engine, gt, lexus, motor, mustang, oil, overfill, overfilled, overfilling
