Ram Air for s197's who can explain to me how to make it work? - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 02-22-2012, 08:28 AM   #11
drfister
drfister's Avatar
If you want ram-air get a cai like the one offered by WMS. http://www.wmsracing.com/wmsweb/WMS-...ntake_Ram.html
And a KR hood or similar, with an opening close to the front. Thats how I would do it.
If you get the C&L then that hood is a good choice, per what jimc mentioned.
drfister is offline   Reply With Quote
Old 02-22-2012, 10:02 AM   #12
Rainson
Quote:
Originally Posted by JimC View Post
It sounds like you have the stock intake - don't cut it to make this dump air in. You will have unfiltered air going in to your engine because the stock set up draws air from the bottom.
None of the options out there are true "ram air".
Get a CAI and open filter like a C&L. This hood is designed with that in mind so that any air coming into the scoop opening is directed to the open element.
I thought the shakercharger is true one..
Rainson is offline   Reply With Quote
Old 02-22-2012, 10:12 AM   #13
gmoran1469
Quote:
Shaker system is but only slighty boosts performance, if any. The real benefit is being able to intake air from completely outside the car.
@OP - Sorry to tell ya but you probably won't see much of a performance boost. These hoods will work better with a CAI than with the stock airbox as well. The benefit you get it being able to get air that hasn't been heated by the engine bay pretty much at all.
gmoran1469 is offline   Reply With Quote
Old 02-22-2012, 11:44 AM   #14
Nuke
Nuke's Avatar
+1 what stags said.
The s197 can only ingest so much air at a time and ram air won't help. Maybe bored and stroked...
Besides looking good, the hood may help reduce heat soak slightly.
Nuke is offline   Reply With Quote
Old 02-22-2012, 01:00 PM   #15
09cs
09cs's Avatar
You don't hook anything up, all it does is it tunnels air over the factory airbox location. You most likely won't feel a difference to be honest.
09cs is offline   Reply With Quote
Old 03-10-2012, 06:42 AM   #16
08 Pony Package
08 Pony Package's Avatar
OP - Can I ask how much prep work time (and dollars, since it seems you had it painted professionally) were involved in having the hood painted? I understand they do not come from Trufiber in ready-to-paint condition and may require a bit more than scuff sanding and primer.
Also...where's the pics of the new hood? What did you end up doing about the airbox?
08 Pony Package is offline   Reply With Quote
Old 03-10-2012, 10:24 AM   #17
05MineralGrayV6
05MineralGrayV6's Avatar
painter said it was one of the nicest fiberglass hoods he has ever seen very little prep its still at the shop. They are charging me 750 to paint both the hood and my new Roush front bumper as far as the airbox goes I plan on getting a CAI with a good heat sheild to block out as much heat from the engine bay as possible and allow the cold air from the ram air hood to blow on top of it.
05MineralGrayV6 is offline   Reply With Quote
Old 03-10-2012, 11:07 AM   #18
BWfVA
Exactly what I was going to say
BWfVA is offline   Reply With Quote
Your Favorite TV Programs...& why? Mr. D Off Topic 142 11-14-2015 04:12 AM
Wilwood/tilton pedal retrofit on 2007 GT flash_xx S197 Handling Section 4 09-21-2015 02:25 PM
GT manual S197 Supercharger or Turbo? lukasoselia 2005-2014 Mustangs 21 09-17-2015 05:57 PM
Torque Bias explained... ccwebb GT S197 General Discussion 2 08-11-2015 07:47 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
2007, air, box, hood, kr, line, make, mustang, painted, pins, ram, s197, stock, trufiber, underside
