HIDs Questions/Concerns
I was trying to purchase HIDs for my 2005 GT Mustang. However, when I went searching I began to become confused on what was needed.
For Example: On HIDExtra.com if you search by make/model it tells you your low beams are H13
When sorting their products by bulb only Hi/Lo kits came up for H13? I thought Hi/Lo kits only came into play when the high beam/low beam were in the same casing?
As on my GT I have my low beams headlights and my high beams on the grill. Can someone break this down for me so I do not purchase the incorrect kit?
Link for bulbs based on car Make/Model
http://www.hidextra.com/Ford-HID-Kit...9131b451caa310
Link to Hi/Lo Kit
http://www.hidextra.com/h13-slim-matte-black-hid-kit
I found this research
1. HID low beam + NO HIGH BEAM (A single beam hid kit)
2 HID low beam + halogen high beam (A Hi/lo HID kit)
3 HID low beam + HID high beam (A bi-xenon HID kit)
Bi-xenon also reffers to cars that come factory with a single lamp housing using an HID that uses a drop sheild to create a high beam and low beam pattern from the same housing. essentially the term bi-xenon is reffering to a
"single housing that uses an HID bulb to create two different beam patterns"
So what is needed for us?
Link to Hi/Lo Kit
You'll need H13s for the headlights and H10s for the fogs. I have a bi-xenon kit. Go to retrosolutionsllc.com and look at their products. High quality stuff and by far the best customer service out there! I'm sure most of the guys on here will agree.
Thanks for the help! I guess we just get screwed and have to purchase multi system kits for our single system headlights haha.
I check out retro however, I think I will stick with HID extra. I have always used them in the past and their customer service is very good as well. Thanks though!
Link to Hi/Lo Kit
Link to Hi/Lo Kit
Option 2 is the cheap way out to give "high beams" but now you are running a halogen bulb with an HID... Kinda stupid...
Most people rarely use their high beams and will opt for the first one to save some coin, but if you use your high beams get option 3. Like I said, there is still only 1 single xenon bulb, the difference is the bulb can move to position it out further in the housing giving more light output.
BTW, If you ever do look to buy from a different vendor, I highly recommend Todd at Retro-Solutions, like Bakerjd does.
Don
DO NOT buy from Hidextra.com. I was cheap and bought their H13 bi-xenon kit. One of the bulbs went out after 3 months. I bought another bulb from them to replace it and it lasted about 2 months. That's when I decided to tear out the Hidextra kit and buy a set from Retrosolutions. Been running with the Retrosolutions HID kit for over a year with no problems.
Link to Hi/Lo Kit
Link to Hi/Lo Kit
Also I recommend Retro-solutions as well, they are a little more expensive but well worth it for the quality!!
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
stangmods.com
121
03-09-2009 01:18 PM
