Sponsored by:
Sponsored by:
replacing oem strut mounts help
Old 03-03-2012, 08:37 AM
wcgman
wcgman's Avatar
Originally Posted by tx_zstang
Too bad. You could have gone with camber bolts and saved a lot of coin.
So something like the camber bolts from Eibach negate the need for replacing the strut mounts? Thats one big reason I havent pulled the trigger on new suspension because I dont want to blow a bunch of extra coin on something I dont really need...
wcgman is offline
Old 03-04-2012, 12:35 PM
pandastang
pandastang's Avatar
can you explain this to me a lil more, im all for saving green but i read no where that camber colts would be better than the steeda mounts
pandastang is offline
Old 03-05-2012, 12:26 AM
White05GT
White05GT's Avatar
You can borrow a spring compressor thru the Advance Auto or Auto Zone loan-a-tool program. Did that when I changed my struts. Pretty sure it was Advance Auto.
White05GT is offline
Old 03-05-2012, 09:18 AM
SCCAGT
SCCAGT's Avatar
Camber bolts only allow for camber adjustability. The reason you are getting the mounts is because the stock ones are a weak point, right? and will start to clunk over bumps. The camber bolts will not do a thing for this.
SCCAGT is offline
Old 03-05-2012, 09:27 AM
bigblue95z
bigblue95z's Avatar
Def need to get the Steeda HD mounts. From what I've read its a waste to get the GT500 mounts are really no different design and still are prone to the popping. I just ordered them myself. The camber bolts only allow for adjustment, and as far as I know have 0 effect on structural strength.
bigblue95z is offline
Old 03-05-2012, 09:28 AM
gmoran1469
gmoran1469's Avatar
Until he had to replace the whole unit later on from wear and tear.
Save yourself the hassle, and the coin in the long run. Get the Steeda mounts and never worry about it again.
Plus they are easy to make hot-swap points for more aggressive camber at the track.
gmoran1469 is offline
Old 03-05-2012, 09:40 AM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
I think tx_zstang was saying get the camber bolts instead of cc plates.
ODDYSEY is offline
Old 03-05-2012, 01:43 PM
SteedaBrandon
Former Sponsor
SteedaBrandon's Avatar
Thanks for all of the Steeda props!
SteedaBrandon is offline
Old 03-05-2012, 11:45 PM
pandastang
pandastang's Avatar
thanks for the info guys, parts are ordered. Just waiting for them to come in...they should actually be in tomorrow! oh yasss. Not gonna lie they are pricey but if it sames me time and hassle later on than spending the money aint bad.
Old 03-12-2012, 12:13 AM
pandastang
pandastang's Avatar
all done with the install....wasn't bad at all to do! gave it a few test drives and i cant believe the difference in the handling, so much better now and im really happy with the stance. thanks everyone for ur input!
Quick Reply: replacing oem strut mounts help
