Sponsored by:
Sponsored by:
replacing oem strut mounts help
Old 02-29-2012, 12:49 PM
pandastang
pandastang's Avatar
Default replacing oem strut mounts help
Ok, so first off I wanted to thank Jazzer for giving me some good info on my suspension. I went ahead and purchased lowering springs along with new shocks/struts. I went with Tein for the springs and the koni strt for the shocks/struts. Parts are in the garage ready to go!
Now time for my question, Ive been reading and searching for a clear cut answer with no luck, but Ive read that once i go and replace the struts I would also have to replace the strut mounts since the oem's wont do so great now the the car is going to be lowered. Ive read that I can either go with gt500 mounts for the steeda hd mounts which are supposed to be way better. Can anyone shed some light on this? ive also read about cc plates...are they supposed to do the same thing? Do I need them in addition to the upgraded mounts? I just wanna get this baby lowered so I'm looking to purchase what I need asap. Thanks for the info!
pandastang is offline
Old 02-29-2012, 03:19 PM
jdmcbride
jdmcbride's Avatar
Just bite the bullet and get the Steeda HD Mounts. If you have problems with the GT500 mounts, you will spend more in labor having to do them again.
jdmcbride is offline
Old 02-29-2012, 03:21 PM
gmoran1469
gmoran1469's Avatar
Steeda mounts are worth the money. Simple install and it makes adjusting your camber a breeze. You can even mark setpoints on them if you want to have different settings to hot-swap to them at the track.
gmoran1469 is offline
Old 02-29-2012, 04:17 PM
pandastang
pandastang's Avatar
Sounds like that's what I'll do today. Would I also need cc plates along with mounts?
Old 02-29-2012, 05:20 PM
Roy_R
Roy_R's Avatar
Nope, don't need CC plates...I would have gotten the Steeda Sport springs instead, works well with those shocks.
http://www.steeda.com/store/steeda-h...d-mustang.html
Roy_R is offline
Old 02-29-2012, 05:27 PM
808muscle
808muscle's Avatar
Do the install yourself.....its not difficult. Spring compressor tool is around $30 and is worth every dollar.
808muscle is offline
Old 02-29-2012, 06:55 PM
pandastang
pandastang's Avatar
thanks for the input, Im gonna go with the steeda mounts, now just gotta find a shop that has em in stock.
Old 02-29-2012, 07:10 PM
Roy_R
Roy_R's Avatar
Can order them direct from Steeda....
Roy_R is offline
Old 03-01-2012, 12:31 PM
pandastang
pandastang's Avatar
ordered, should be here next week. ill have pics once installed.
Old 03-01-2012, 09:41 PM
tx_zstang
tx_zstang's Avatar
Too bad. You could have gone with camber bolts and saved a lot of coin.
tx_zstang is offline
Quick Reply: replacing oem strut mounts help
