engine knocking?
engine knocking?
hay guys when car is running at normal temp im hearing knocking with a rattle in 2nd,3 and 4th at about 2000 rpm under load. at idle sounds normal, cold or hot. Reving engine everything sounds ok.
Contact Ford of Canada Customer Service Center at 1.800.565.3673. The rep will document and assist you with that concern.
Noemi
From the description, it sounds like the same thing that I had since like 1300 miles. (20,000 now) Reapeated trips to the dealer later, they claim they don't hear it. It's a light knock noise, between 2-3k RPM, only under load (like light acceleration), but def not detonation. I think it's something to do with the variable cam timing but dealer kept blowing me off. Did it bone stock, with a tune, trying many filling stations. I suppose I shouldn't be worried about it, but it still bugs the crap outta me every time I drive it.
