Sponsored by:
Sponsored by:
Rear-end walks during burnout
Old 03-03-2012, 12:33 AM
ponyman
ponyman's Avatar
Default Rear-end walks during burnout
Hey all,
I was at the track a few weeks ago and the Mustang was doing something that it doesn't normally do.
When I would do a standing burn-out the rear-end kept walking out to the left. Most of the time it wasn't just a little bit, but the whole car would start to go sideways.
Any thoughts? Is this normal? If not, what might I be looking at for causes?
Thanks!
ponyman is offline
Old 03-03-2012, 09:08 AM
SCCAGT
SCCAGT's Avatar
The ground was more than likely sloped a small amount in that direction. If there is room for it, try facing the other direction at the same spot and see if it goes to the right. I'll bet that is what will happen.
SCCAGT is offline
Old 03-03-2012, 09:22 AM
MoshpitMad
MoshpitMad's Avatar
Facing the other direction at the track?
MoshpitMad is offline
Old 03-03-2012, 09:39 AM
tomkay
tomkay's Avatar
Don't know the answer for you but it seems to be fairly common occurrence on the tv show Pass Time.
tomkay is offline
Old 03-03-2012, 11:47 AM
MustangFirstCar
MustangFirstCar's Avatar
He means angle the car just a little bit so it won't slide left as much. It happens to me sometimes too but I always attributed it to the open diff giving power to only 1 wheel.
MustangFirstCar is offline
Old 03-03-2012, 11:58 AM
pascal
S197 Section Modder-ator
pascal's Avatar
I like the thread title...
Cause that's what the wife says.
pascal is offline
Old 03-03-2012, 12:14 PM
MoshpitMad
MoshpitMad's Avatar
Your wife says "rear end walks during burnout"?
Old 03-03-2012, 12:25 PM
pascal
pascal's Avatar
Some like that.
pascal is offline
Old 03-03-2012, 02:10 PM
SCCAGT
SCCAGT's Avatar
Allow me to change my response somewhat. I'll bet one of two things is making this happen. first one is the surface isnt absolutely level. Not so likely to be the case on a track, but, possible nonetheless.
Second possibilty is that one tire isnt spinning at the exact same speed as the other. If one wheel was not spinning, the car would remain stationary from side to side
SCCAGT is offline
Old 03-03-2012, 02:34 PM
Nuke
Nuke's Avatar
Nuke is offline
Quick Reply: Rear-end walks during burnout
