Sponsored by:
Sponsored by:
QA1 bump steer kit (need pics/info)
Old 03-03-2012, 12:08 PM
bullitt ben
bullitt ben's Avatar
Default QA1 bump steer kit (need pics/info)
So I'm just about to install QA1 Bump steer kit,
Been searching for info and found factory install instructions (which btw are very close to the STEEDA 's) .
I have found pics that S197 owners have posted and some show most of the washers on top of rod end while some show most of the washers below rod end.....Is there that much difference in suspension setups?
However every instructions and tutorials i have found mention adjusting tie rod shaft/tie rod assy as parrallel to control arm as possible to be in the right ballpark...do you need to put load on suspension to adjust this?
any info / pics on this topic would be greatly appreciated.
bullitt ben is offline
CS2007
06-25-2019 09:45 PM
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: QA1 bump steer kit (need pics/info)
