Sponsored by:
Sponsored by:
Fog light wiring
Old 03-03-2012, 07:15 PM
Warpig12354
Warpig12354's Avatar
Default Fog light wiring
I just installed a billet grille on my 07 v6 and I previously had the stock GT grille with the fogs that were wired to my light switch. Since I was no longer using them I cut the harness off and now there's two wires floating around that were left over. Is it okay if I just put electrical tape over the ends? Or do I have to take them completely out? Thanks.
Warpig12354 is offline
Old 03-03-2012, 08:18 PM
Nuke
Nuke's Avatar
I'd tape them but I'd also pull the fuse. Here's the wiring diagram: http://iihs.net/fsm/?dir=40&viewfile=Fog Lamps.pdf
Nuke is offline
Old 03-03-2012, 11:23 PM
tx_zstang
tx_zstang's Avatar
Or pull the foglight relay, and tape the cut ends, making sure the cuts do not contact each other nor the frame.
tx_zstang is offline
Old 03-04-2012, 08:38 AM
Chromeshadow
Chromeshadow's Avatar
I like to fold the end of the wire about an inch and cover about 2 inches with with heat shrink. Tape will eventually slide off when it gets hot, might take ten years.
Chromeshadow is offline
Old 03-04-2012, 09:16 AM
Warpig12354
This is what I was gonna do, I already took out the relay.
Old 03-04-2012, 10:27 AM
Ditty
Ditty's Avatar
Heat shrink is your friend. Do it right. If not, possibe electrical gremlins are in your future.
Ditty is offline
Ford_Dude
09-15-2015 03:25 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Fog light wiring
