AFE Cold Air Intake
The reason some intakea need a tune, is the bigger intake tube that flows a lot more air.
A tune will make more than just a CAI..A CAI kit is not just about cold air. Other advantages of new intake plumbing: less restriction. This may be a result of a more-porous filter, larger intake tube diameter, smoother plumbing, or less bends and turns in the plumbing. By looking at the AFE kit, I dun see anything better than stock air box other than a bigger air filter, which does nearly nothing.
that AFE tubing so small i cant see how you can pull much more air other than the filter but, it seems to (just me) that you would max out that tubing, if you look at products such as the jlt and c&L there tubing is twice the size allowing more air flow with less resitance, (again i could be wrong, wouldnt be the first time) if it was me i would spend a couple more dollars and get a bigger induction
and if you don't get it, click on either CAI tune required kit (not combo), there's a link says
"why a tune required".
anyways, I'll link it here....
http://www.americanmuscle.com/why-tu...cai-popup.html
OMG....read the product info before you ask....
I think you missed the most important part... the FRPP CAI has a 85MM MAF housing, comparing to the stock 76mm, it's 11+% more air running pass the MAF sensor...That's why I asked you to check out the video before asking..
If you dun get a tune for that 11% more air, some how there's a thing called "check engine light" will annoy you..
those no tune CAI, all of them are equiped with the 76mm MAF housing, which is as same as the oem size to avoid computer error.
The curve part is for general CAI kits, not just for s197 Mustangs. most CAI for S197 has a huge curve anyways.
You actually BELIEVE the advertised info? Really?
At best, you'll gain 3-5 RWHP, tops, w/o a tune. But dingo ***** hung from ther headliner; now THERE'S some power gain... I read it somewhere...
A CAI can have a maul the size of the grand canyon but if the computer can't compensate for the extra air (plus the engine has to be capable of passing the extra air) it doesn't do a bit of good. You're being swayed by bullchit advertising hype.
so funny lol, .. the C&L has a 90mm MAF Housing, one of the reasons i went with it
