Subframe connectors? - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 03-27-2012, 09:52 PM   #11
2005Redfire6
I've been hearing more and more that they aren't really necessary...
2005Redfire6 is offline   Reply With Quote
Old 03-27-2012, 10:03 PM   #12
obxdude018
obxdude018's Avatar
They really aren't unless you were doing some intense racing, I have subframe connectors welded in. I will say I can all but jack up 3 out of 4 tires from a single jack point, that's how stiff my car is.
obxdude018 is offline   Reply With Quote
Old 03-28-2012, 03:45 AM   #13
07 GT E UPP
07 GT E UPP's Avatar
Not really necessary, most say , but I put the Steeda 3 Point Frame Rail Braces on mine
just in case...LOL
07 GT E UPP is offline   Reply With Quote
Old 03-28-2012, 06:56 AM   #14
wcgman
wcgman's Avatar
If you want to deal with wheel hop, you need at least LCA's. I was getting a lot of wheel hop and this last weekend just put LCA's in and the wheel hop is now gone. The link for them is below and it's totally worth the 100 bucks.
http://www.americanmuscle.com/2005-p...ling-arms.html
As for a UCA, I havent done that but I believe that it would handle axle rotation which should ultimately help with wheel hop as well.
For the frame flex, you can get into stiffening, but I can tell you that my old mustangs had a lot more flex than the 06 and 10. That's why I dont think you need to make the frame more rigid unless you really get into racing it, and then it becomes kind of specific beyond my knowledge and skills.
wcgman is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 04:23 PM
Outer shock tower braces guitarman376 Classic Mustangs (Tech) 6 10-11-2015 01:47 AM
need traction mikesr4565 Suspension 5 09-21-2015 10:26 AM
Steeda’s Vortech S550 Goes 11.2 on Street Tires in Road Race Trim tj@steeda Steeda Autosports 0 09-16-2015 07:53 PM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 12:08 PM
2010, 2012, connectors, convertible, coupe, flex, gt500, ii, mustang, s197, subframe
