Sponsored by:
Sponsored by:
Subframe connectors?
Old 03-27-2012, 06:17 PM
DSargent09
DSargent09's Avatar
Default Subframe connectors?
are they needed on the 2012 Mustang.... Just bought some race star wheels w/ slicks and have been told these are a must.
DSargent09 is offline
Old 03-27-2012, 07:09 PM
onederful100
onederful100's Avatar
depends.
what kind of racing are you doing, and what kind of power you puttin down.
if you just go occasionally, and only have bolt ons, then i would say you dont need them.
but they really arent that expensive anyways.
onederful100 is offline
Old 03-27-2012, 07:13 PM
legendlime05
legendlime05's Avatar
imo as long as youre not lifting the the fronts, then no.
legendlime05 is offline
Old 03-27-2012, 07:15 PM
DSargent09
DSargent09's Avatar
I put down 406 RWHP, and now will be running 15" racestars w/ slicks.
Old 03-27-2012, 07:18 PM
wcgman
wcgman's Avatar
I wouldnt worry about it yet.
wcgman is offline
Old 03-27-2012, 07:20 PM
DSargent09
DSargent09's Avatar
Is it true they will help reduce wheel hop? Going into second was ridiculous.
Old 03-27-2012, 07:36 PM
Alec
Alec's Avatar
From the factory the chassis is pretty rigid, not necessarily the case with the older generations, so SFC are not really necessary. There are better suspension mods
Alec is offline
Old 03-27-2012, 08:01 PM
onederful100
you should look into some suspension packages. like sam strano, UPR, stangsuspension, etc.
is your suspension stock right now?
Old 03-27-2012, 08:15 PM
Moderator
JimC's Avatar
With the pre-2005 (S197) cars they were a "must" because of the flex in those bodies.
The person who told you that with your 2012 they are a "must" is thinking of older Mustangs. My convertible even doesn't flex - and I've driven a friend's S197 convertible with almost 600 to the rear wheels, lifting both front tires on the launch, and no flex. So if a convertible doesn't flex, then the coupe won't have a problem.
JimC is offline
Old 03-27-2012, 08:26 PM
onederful100
http://www.uprproducts.com/mustang-s...evel-1-11.html
control arms are a good place to start.
Quick Reply: Subframe connectors?
