Sponsored by:
Sponsored by:
CAI and Bama tune.. Disappointed so far
Old 03-27-2012, 09:10 PM
  #21
legendlime05
legendlime05's Avatar
holy huge intake batman! jeez makes intake looks small.
did bama tune the car to the boss intake?
legendlime05 is offline
Old 03-27-2012, 09:12 PM
  #22
2012Kona
2012Kona's Avatar
I haven't got the tune files for the intake swap yet. That wasn't in the mix till after I ordered the CAI/Tune kit. Freakin cars. I knew there was a reason I haven't driven a Mustang in almost 10 years.
2012Kona is offline
Old 03-27-2012, 09:13 PM
  #23
legendlime05
so what was the car tuned for? was it tuned for the airaid at least? its not the cars fault....
either a faulty tune or somethings going on. check all the connections on the intake?
Old 03-27-2012, 09:16 PM
  #24
2012Kona
2012Kona's Avatar
It was supposed to be tuned for the CAI and exhaust I have. Nothing else. I've checked all connections. Took the system completely out and put it back together. The only thing that is somewhat suspect is the direction of the MAF sensor.
2012Kona is offline
Old 03-27-2012, 09:21 PM
  #25
legendlime05
did you reupload the tune itself? if not then i got nothing. contact bama. **** happens and mistakes can be made. i know when i got my tune from them it was night and day.
Old 03-27-2012, 09:27 PM
  #26
2012Kona
2012Kona's Avatar
No, I haven't reflashed yet. Decided to step away for the night.
2012Kona is offline
Old 03-27-2012, 09:35 PM
  #27
jrockgts197
jrockgts197's Avatar
Does your MAF have an arrow on it? If it does then the arrow should be pointing in the direction of intake air flow. Also, I had a problem similar to yours when I installed my CAI/tune and it went away when I disassembled everything, cleaned the throttle body and MAF, and reassembled. It's unlikely but it could be a bad tune. Just throwing ideas your way.
jrockgts197 is offline
Old 03-27-2012, 10:07 PM
  #28
obxdude018
obxdude018's Avatar
91 Oct shouldn't cause any problems, your best bet is return your car to stock try reloading the tune and if that doesn't work call bama.
obxdude018 is offline
Old 03-27-2012, 10:28 PM
  #29
MadStang40
MadStang40's Avatar
Originally Posted by obxdude018
91 Oct shouldn't cause any problems, your best bet is return your car to stock try reloading the tune and if that doesn't work call banana.
One does not simply call banana!
But seriously, time to talk with Bama. Tell them what you're experiencing. They'll be able to tell you if the tunes they sent you were good. First try to return to stock then reload the tune. Takes two minutes, then take a 5 minute test drive.
If Bama tells you that they're tunes were correct (I'd check to make sure you gave them the correct ECU code too...) then maybe it's time to clean that MAF and throttle body then hook her back up.
As far as cleaning and re-oiling an air intake: it's a process that literally takes 20 minutes. I cleaned mine just three weeks ago. You're only supposed to clean it every 50k miles. Really not that big of a hassle.
MadStang40 is offline
Old 03-27-2012, 10:33 PM
  #30
jrockgts197
Call "banana"? Can't wait to see what the banana says lol. Just playing obxdude. Autocorrect? lol
OP, check the MAF arrow (if it has one) then triple check your connection points for the CAI and make sure they are perfectly sealed. It can be misleading because they look fine but might be leaking a tiny bit. After I cleaned everything I could move my intake around and the idle would improve so I knew I had a leak somewhere. Reload the tune (no need to go back to stock and then reload) and try again. If all else fails go back to stock and call Bama/AM like obxdude suggested. Please keep us posted.
^^ D#%! madstang beat me to it!
Quick Reply: CAI and Bama tune.. Disappointed so far
