Would a 20x12 rim fit on the rear?
#25
#27
to answer the OP's question, yes. 20x12's fit. 345s won't "fit" unless you consider sticking out of the fender 10+mm "fitting"
these are 20x12 rotiform BLQs. et 61 with 3mm spacers here. a watts link should let me take the spacers out. 315/30/20 toyo R888 tire in the rear. rubs the inner fenderwell very very faintly only when the rear end is articulating all the way. the bump stop bracket has been trimmed and the bump stop is relocated. a little bit of the fender liner was trimmed out too.
#28
09-08-2015 11:50 AM
