Sponsored by:
Sponsored by:
need help ASAP!!!
Old 04-09-2012, 10:04 PM
shad2009
shad2009's Avatar
Default need help ASAP!!!
so this all started when i went to get my car inspected and it failed the emission part because my o2s were turned off, so i called bama to get the updated tune for the 87 and 89 octane that has the o2s turned on and i loaded it and my check engine light came on saying the o2s were stuck on rich...so i called bama again and they said i had to update the firmware but first return my car to stock...so i get home from work, return to stock and go inside to update the firmware and it said there was an error and now my tuner is stuck on the screen saying "system start up...please wait...filesystem error...needs to be reloaded"
any suggestions that would not involve having to call somebody in the morning and probably have to be late for work
shad2009 is offline
Old 04-09-2012, 10:09 PM
Young_Gun
Young_Gun's Avatar
Disconnect the battery for 10 minutes so it all resets, then try to load the stock tune again
Try connecting your tuner to your computer and seeing what you can do with it from there to make sure its an issue with the PCM and not the tuner
Good luck
Young_Gun is offline
Old 04-09-2012, 10:29 PM
shad2009
shad2009's Avatar
the stock tune is loaded...it's the tuner, it's stuck on that screen
shad2009 is offline
Old 04-09-2012, 10:46 PM
ReaperGT
ReaperGT's Avatar
If your stock tune is loaded, go get your car inspected again then afterwords call bama and have them walk you through the re-tuning
ReaperGT is offline
Old 04-09-2012, 10:49 PM
awakeinAZ
awakeinAZ's Avatar
You have to drive 50 miles before the emissions inspection. It's also possible the tune got corrupted via email. Sounds strange but that happened to me and they sent the same tune next day uploaded and worked fine.
awakeinAZ is offline
Old 04-09-2012, 10:50 PM
shad2009
shad2009's Avatar
cant drive the car with the jlt intake (don't have the stock air box) and i cant get away from this screen...i put that up to see if anybody has had this screen come up before...looks like i'm going to have to make a phone call in the am
shad2009 is offline
Old 04-09-2012, 10:55 PM
aaquib1992
aaquib1992's Avatar
So the tuner interface is frozen? Might need to contact SCT about that. Did you try updating it again? Will it even go into "update mode" after holding the cancel button?
aaquib1992 is offline
Old 04-10-2012, 12:51 AM
Lem-06
Lem-06's Avatar
maybe for now find someone who has a modified stang and see if they still have stock air box to get you through inspection then spend time fixing this.
hope you get it fixed soon
Lem-06 is offline
Old 04-10-2012, 05:35 AM
Nuke
Nuke's Avatar
If I was close I'd offer to lend you my OE airbox but that isn't the case. Put out an A.P.B., I suppose.
Nuke is offline
Old 04-10-2012, 06:06 AM
shad2009
shad2009's Avatar
the screen goes blank when i hold cancel and that's it
shad2009 is offline
Quick Reply: need help ASAP!!!
