Sponsored by:
Sponsored by:
Hot air coming from vents?
Old 04-11-2012, 11:36 AM
Tarantula_Keeper
Tarantula_Keeper's Avatar
Default Hot air coming from vents?
Hi I'm new here and have a question. I have an 05 GT 5 speed and I've noticed that when driving I am getting warm to hot air coming out of my air vents, primarily out of the 2 center vents. It only does this when I have the air shut off. If I put the a/c on it blows cold and blows hot when I put the heat on. The temperature gauge reads normal as well. Is there anything I should be worried about?
Tarantula_Keeper is offline
Old 04-11-2012, 12:40 PM
AzPete
AzPete's Avatar
Sounds like the normal fresh air from the outside.....coming past the rear of the hood into the vents.
AzPete is offline
Old 04-11-2012, 12:47 PM
josh87
josh87's Avatar
My car does the same thing. I couldnt tell you why. I dont think you have to much to worry about.
josh87 is offline
Old 04-11-2012, 12:59 PM
onederful100
onederful100's Avatar
close the vents.
onederful100 is offline
Old 04-11-2012, 01:01 PM
gmoran1469
gmoran1469's Avatar
Fresh air coming in is hot, that's all.
gmoran1469 is offline
Old 04-11-2012, 01:10 PM
BigDinTexas
BigDinTexas's Avatar
Trick I learned on the '05: The trick to close those fresh air vents when driving with the windows down is to simply turn the MAX AC on for a couple secs... just long enough to have cold air coming through then turn off the AC. Viola, no more hot air... atleast until you power off the car and get back in... Then it will reset for some strange reason.
Don
BigDinTexas is offline
Old 04-11-2012, 01:31 PM
Tarantula_Keeper
Alright thank you for your help everyone
Old 04-11-2012, 07:16 PM
Nuke
Nuke's Avatar
Flow thru ventilation.
First car, huh?
Nuke is offline
Old 04-11-2012, 07:37 PM
pascal
S197 Section Modder-ator
pascal's Avatar
^^^^^^^^^^^ You're full of hot air, first car or not!
pascal is offline
Old 04-11-2012, 08:39 PM
Tarantula_Keeper
First car, huh?
Why does it have to be my first car? No other car I've owned has done this and I've owned my mustang since 08 and it just started doing this this past winter.
Quick Reply: Hot air coming from vents?
