Rattle / Buzz @ 1500 RPM
*Sigh*...
I hate when a car is great to me and then one thing goes wrong, and then it seems like its one problem after another...
I've developed a metallic rattle right at 1500 RPM. I've eliminated to exhaust hangers (had that before). Only occurs when the car is in gear (not neutral). Noticed it this morning on initial startup. Seemed to go away after about 5 minutes. Noticed again on startup on way home. Seemed to go away after 5 minutes. Showed up again right when I got home.
I'm hoping someone will say, "that can't be your cats, its most likely _____________"
Help?
I might try and throw a video up tomorrow if I can...
Help?
One of 3 things:
- axleback clamps - torque an additional 1/4-1/2 turn (or more if they're loose)
- separator plate - read the TSB
- heat shields
Turns out the weld on one of my axlebacks had failed and the hanger was rattling like a mother. After removing the bracket I could strum on the thing and it would chatter for 10 seconds plus....
Pretty crappy weld from Pypes if you ask me, they're only about 2 years old...
+1 classic symptoms if you search. try a couple of rubber washers on the bottom two bellhousing bolts as a cheap fix.
