How to clean the air filter
Assuming your filter is the oiled type, then it's pretty simple to do but takes a good 12-24 hours.
Most kits come with a degreaser which obviously you use with hot water to rinse the dirt and old oil from the pleats. Be sure to wash from the inside out , otherwise you end up forcing the dirt (which is sitting on the outside of the pleats) into the pleats. Afterwards, the filter MUST BE BONE DRY before applying fresh oil; the drying process may take 12 hours but I always give it more time. Once it's dry, I give it a few light sprays of oil around the entire perimeter, wait a few minutes and repeat the light sprays.
Fortunately for me, my Stang isn't my DD in that respect so I can do without it for 24 hours. If it was my DD, I'd buy a spare filter so I could rotate them and not rush the cleaning.
Most kits come with a degreasing spray which I'll put money down is nothing but dish detergent or something on the order of Simple Green. Years ago I used an oiled Amsoil drop-in filter in my SUV and I always washed it with dish detergent. As long as you use something that'll cut the grease, not attack the element material and will rinse out thoroughly you'll be good to go for the re-oiling.
