how much psi can the stock block handle - Page 2 - MustangForums.com
Old 05-01-2012, 06:56 AM   #11
eolson
eolson's Avatar
I have an 06 as well. Some believe from a lot of high HP and dyno sessions that the 05's and 06's had more robust internals and did not break nearly as often as the 07's, 08's and 09's. This was varified by many shops on this forum a few years back.
Since you have an 06' as I do, I finally settled on 10 psi since I don't drag race, and it's controllable power coming into and out of turns, and launching when feathering 1st gear properly. On basically stock exhaust I've been at 376rhhp@4 psi, 415rwhp@8psi, 507rwhp@14.5psi, 475rwhp@12 psi, and now 454rwhp@10psi, all tunes basically at 16 ignition timing on my Saleen series VI.
No problems so far. Knock, knock!.......on wood......... Erik
eolson is offline   Reply With Quote
Old 05-01-2012, 08:25 AM   #12
2006mustanggtowner
thanks for all the info i think ill go with that and just run around 8psi to be safe and just buy a sct programmer and put my cold air back on and just leave my exhaust the way it i. thanks alot
2006mustanggtowner is offline   Reply With Quote
Old 05-01-2012, 01:18 PM   #13
808muscle
808muscle's Avatar
What blower are you planning on installing?
808muscle is offline   Reply With Quote
Old 05-01-2012, 08:43 PM   #14
CutterWolf
CutterWolf's Avatar
I have an 06 and I'm pushing 10.5 psi on my with out issues but then again I don't drive my car like a moron either. If you take care of you car it will take care of you and let you run big power without much trouble. I ended up putting down 498RWHP on my auto trans at that psi and that was before we even tried to lean out the AF level. So I was hitting those numbers with an AF of 10.5 which is crazy. In the end we ended up taking out 3 degrees of timing to make it a little safer which took me down to 475RWHP range. But it was really nice knowing that my car could hit over 500RWHP with just leaning out the AF. But I will wait till I have the funds to buy a stroked 302 short block and then punch it up into the 600+ range
CutterWolf is offline   Reply With Quote
Old 05-09-2012, 12:32 AM   #15
2006mustanggtowner
ive been looking at the vortech superchargers the most . next would probally be a kenne belle does anyone have any other suggestions and thanks for all the help.
Old 05-09-2012, 12:33 AM   #16
2006mustanggtowner
to everyone
Old 05-09-2012, 02:45 AM   #17
Thrashard340
Quote:
Originally Posted by Diabolical! View Post
I've been running 500rwhp and 12 psi forever. Even launching on slicks and shifting at 6500 rpms hasn't hurt my stock block with 200ish passes at the drag strip.
You got a good combo working for you. Not everybody else running 500HP can say the same.
Thrashard340 is offline   Reply With Quote
Old 05-09-2012, 06:58 AM   #18
07 GT E UPP
07 GT E UPP's Avatar
For me, over the last 4 years, I've been running stock internals with
11 psi, great tune, 94 octane, about 14 degrees timing, shifting at 6500, etc. etc. And, All is well so far !!
07 GT E UPP is offline   Reply With Quote
Old 05-09-2012, 07:25 AM   #19
eolson
eolson's Avatar
Cutterwolf, what supercharger do you have?
500rwhp @10.5psi sounds like a centrifugal supercharger to me. On a twin screw with responsible timing you'd need to be on 12psi with very open exhaust to see 500rwhp with a 12.0 air/fuel ratio.
My idea of Best Bang for Your Buck Car. What do you guys think? mungodrums 5.0L GT S550 Tech 7 10-07-2015 05:01 AM
Upgrading to handle slicks? Info needed Dragonus18 4.6L (1996-2004 Modular) Mustang 8 09-09-2015 02:21 AM
The Future of my GT vintageaion 2005-2014 Mustangs 2 09-08-2015 11:45 AM
Best Extreme Performance Summer Tires for our Mustangs? M3hunter S197 Handling Section 0 09-05-2015 04:42 PM
2006, 2011, 2012, 50, blower, boost, gas, handle, handls, mustang, pressure, psi, saleen, shock, stock, waste
