Sponsored by:
Sponsored by:
Hot! Shift stick??
Old 05-02-2012, 10:42 AM
xkape
xkape's Avatar
1SilverGT - Mine gets relatively hot on long draves as well. Roush short shifter. If you are referring to roughly around where the "Roush" is engraved in the shaft.
xkape is offline
Old 05-02-2012, 11:52 AM
Old Mustanger
Old Mustanger's Avatar
Originally Posted by 1SilverGT
After awhile of driving my mustang the shift stick gets hot not hot that it'll burn if you touch it, but it get really hot inside the car around the shift stick area. Any suggestions as why that happens or if its normal? bad?
my mustang has a roush shift stick
Sounds like the trans fluid has lost it's lubricity.
It would be a relatively inexpensive upgrade to change to a good quality synthetic fluid. That should reduce the trans temp significantly.
Old Mustanger is offline
Old 05-02-2012, 12:39 PM
1SilverGT
1SilverGT's Avatar
yes mine is the roush short shifter with roush engraved in the sides
1SilverGT is offline
Old 11-18-2012, 09:41 PM
Roland210
Roland210's Avatar
Lightbulb Stick shifter getting hot
My 02 GT was doing the samething, the shifter and transmission area were hot even on short trips. The problem went away after I put a spring on the clutch cable to keep the throwout bearing off the pressure plate while the clutch was engaged. Look up, "freeplay clutch correction kit" for ideas on how to install the spring.
Roland210 is offline
Old 11-18-2012, 11:04 PM
drewsky
drewsky's Avatar
Mine gets a little warm in the summer after driving trough town for over a half hour or so. Never noticed it after it started cooling off outside however...
drewsky is offline
Old 11-19-2012, 05:18 AM
moosestang
moosestang's Avatar
We have a hydraulic clutch.
moosestang is offline
Old 11-19-2012, 08:15 PM
slickman
slickman's Avatar
Mine did that till I changed the fluid over to GM synchromesh
slickman is offline
Thunderball
15
11-22-2015 11:49 PM
Explosive
10-02-2015 07:45 AM
BeatnikFink
10-01-2015 08:00 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Hot! Shift stick??
