Why shouldn't you use the differential...
Pretty much this reason..
https://mustangforums.com/forum/2005...rs-beware.html
This solved it...
I still pumpkin jack all the time..
This solved it...
You shouldn't need anything between the jack and the diff unless you have some type of odd jack with fingers sticking WAY up.
You can sit the jack centered below the diff and it won't even touch the cover.
If you messed it up from using the diff to raise the rear end then you did something wrong.
I don't use a 2x6, phone book, or anything, just a jack. I've never had a problem on ANY of my cars from a 98 Jeep Wrangler, to a 1985 FB3S, to the S197.
If you broke something you were doing it wrong in the first place.
