Sponsored by:
Sponsored by:
Decisions, Decisions. I need a little advice.
Old 05-11-2012, 06:37 PM
  #21
S197GT07
S197GT07's Avatar
He is using the spring compressor. There is no better guide than Hammeron's here on the site. Pretty sure its a sticky in the tech section. I used that when I installed a set of hotrods and it was spot on.
S197GT07 is offline
Old 05-11-2012, 06:40 PM
  #22
Roush05
Roush05's Avatar
I'm about to head out to eat but I'll definitely read it when I get back!
edit: I'm sitting here waiting so I looked for the thread and couldn't find any posts by hammeron. If you know where it's located it would be a big help.
edit: never mind, found it while looking at s197forum. lol.
edit again: Here is the link: https://mustangforums.com/forum/gt-s...ion-guide.html
However, he uses the valve spring compressor as well.
Roush05 is offline
Old 05-11-2012, 07:37 PM
  #23
S197GT07
S197GT07's Avatar
Really? Bush
All you have to do is back the cam caps off to the point where you can fish out the 3 non loaded followers when the motor is at the 12:00 position
S197GT07 is offline
Old 05-11-2012, 07:56 PM
  #24
Roush05
Roush05's Avatar
The cam caps are the things holding the cam in place, right? I'm not sure which 3 followers to pull but i'll look when I get back.
Roush05 is offline
Old 05-11-2012, 09:39 PM
  #25
siggyfreud
siggyfreud's Avatar
The non-loaded followers should be the ones not engaged by a cam lobe.
siggyfreud is offline
Old 05-11-2012, 09:43 PM
  #26
Roush05
Roush05's Avatar
Okay. Going from Hammeron's install, it would be these then, for the right side?
RH SIDE: Using the Valve Spring Compressor, remove
the 3 camshaft roller followers, shown in the illustration.
CAUTION: Do not allow the valve keepers to fall off the valve or the
valve may drop into the cylinder.
NOTE: The camshaft roller followers must be installed in their
original locations. Record camshaft roller follower locations.
NOTE: It may be necessary to push the valve down while compressing
the spring.
Roush05 is offline
Old 05-12-2012, 10:03 AM
  #27
siggyfreud
siggyfreud's Avatar
Looks right. In the pic all three lobes are pointing away from the cam.
Old 05-12-2012, 11:27 AM
  #28
Roush05
Roush05's Avatar
I'm on my phone so my searching capabilities are limited but the three lobes that aren't pushing on a valve?
Roush05 is offline
Old 05-12-2012, 09:57 PM
  #29
808muscle
808muscle's Avatar
Hamerons. DIY is spot on. Its what I used too.
808muscle is offline
Old 05-12-2012, 10:18 PM
  #30
Roush05
Roush05's Avatar
Sounds good! I just talked to a buddy who has done this before and is gonna help me do it. I feel a lot more secure having someone experienced there with me.
Roush05 is offline
Quick Reply: Decisions, Decisions. I need a little advice.
