Sponsored by:
Sponsored by:
Decisions, Decisions. I need a little advice.
Old 05-12-2012, 11:39 PM
  #31
808muscle
808muscle's Avatar
Originally Posted by Roush05
Sounds good! I just talked to a buddy who has done this before and is gonna help me do it. I feel a lot more secure having someone experienced there with me.
Thats a very good idea. While the swap is not overly difficult you could f*ck up your stuff real bad if you dont pay attention to all those pesky followers.
808muscle is offline
Old 05-13-2012, 12:38 AM
  #32
Roush05
Roush05's Avatar
There's that, and then the distinct possibility that I would knock the timing chain wedge loose and have to have someone re-time my engine. I don't even know what that entails, but it has to be expensive.
Roush05 is offline
Old 05-13-2012, 08:49 AM
  #33
S197GT07
S197GT07's Avatar
As soon as you pull the valve covers, go CRAZY with the sharpie!
Get the engine to 12:00, and mark the **** out of the phaser and chain so you KNOW if you jumped a tooth. Also, when swapping the cam out, have person #2 just hold the phaser with tension so there is no WAY it could jump. Thats how I did it and I didn't feel as if there was a possibility to skip a tooth.
S197GT07 is offline
Old 05-13-2012, 09:42 AM
  #34
Roush05
Roush05's Avatar
Will do. The guy isn't shipping until Monday so I don't know when it will be here :/ What exactly happens if it were to slip?
Roush05 is offline
Old 05-13-2012, 10:49 AM
  #35
S197GT07
S197GT07's Avatar
If it skipped a tooth, you need to take the front cover off and re-time the engine. It's fairly straight forward, but lets cross that bridge if we have too.
Again, if you have somebody hold the phaser with some tension on the chain while you go get the new cam you shouldn't have an issue.
If it skipped a tooth and you didn't know it, the car would run like crap.
S197GT07 is offline
Old 05-13-2012, 12:23 PM
  #36
Roush05
Roush05's Avatar
Gotcha. We'll be extra careful. Either tomorrow or Tuesday I'm going to attempt the header install. I'll keep you updated.
Roush05 is offline
Old 05-13-2012, 02:15 PM
  #37
S197GT07
S197GT07's Avatar
Sounds good man. Header install is easy!
Take off intake & remove battery tray to get the top 8 studs.
Have fun with the bottom 8, some are fun to get at. A closed end ratcheting wrench will be your friend.
Then drop the starter to get the pass side header in, and remove the steering rack for the drivers side.
So easy, a caveman could do it!
S197GT07 is offline
Old 05-13-2012, 03:31 PM
  #38
Roush05
Roush05's Avatar
I assume the lift is gonna make it a lot easier?
Roush05 is offline
Old 05-13-2012, 03:54 PM
  #39
808muscle
808muscle's Avatar
Lift for a header install...........not really needed. You better have a 13mm flexhead racheting box wrench and a pair of gloves thats for sure. Otherwise frustrations will run high and blood loss will be significant!! Anybody whom has installed them knows what I'm saying. Expect it to take at least one day too.
You do NOT want to fubar your timing..........get a timing wedge or make one.
Old 05-13-2012, 04:50 PM
  #40
S197GT07
S197GT07's Avatar
A ton. After you get the top ones, you just lift it up, take out the midpipe, and go to work on the bottom studs.
As 808 said, gloves are a must.
S197GT07 is offline
Quick Reply: Decisions, Decisions. I need a little advice.
