Sponsored by:
Sponsored by:
stock p zero tires worn out after 16K miles
Old 05-14-2012, 04:17 AM
moosestang
moosestang's Avatar
Yeah, the pzero nero don't have enough grip to wear out. I spun those for 38,000 miles and finally had enough.
moosestang is offline
Old 05-14-2012, 05:37 AM
fordplay
fordplay's Avatar
Yeah i got 14,000 out of mine. I did run mine hard, kinda. So 16,000 yeah you are on the high side!! Ha ha, and yeah the p zero nero is a v6 all season brick i ran those pos in my focus. Glad they are gone
fordplay is offline
Old 05-14-2012, 08:17 AM
rogan01
rogan01's Avatar
Thanks for all the great feedback! Seems like this may not be too unusual. The wear was pretty even across the tire. I will probably replace them very soon with one of the other tires recommended on this forum. btw - I live in South Florida.
Thanks again for the help - greatly appreciated.
rogan01 is offline
Old 05-14-2012, 08:45 AM
BigDinTexas
BigDinTexas's Avatar
Well, you should have mentioned that in the first post... That explains it all then...
As I understand the problem, the reason your tires have gone before their time is because of all the HOT! ladies on the beaches there and that hotness just permeates to the pavement causing the rubber to literally melt and be left on the road... No wonder you need to replace the tires... Of course this is based on the premise that you post plenty of pics of said hawt babes in bikinis, 2 piece of course.
Glad I could help,
Don
BigDinTexas is offline
Old 05-14-2012, 10:10 AM
dcarlinf1
dcarlinf1's Avatar
I got 14,000 out of mine. They were down right dangerous by the time I took them off. Only about a 1/16" left per the wear indicators. Seems to be normal for this tire. I hoped I would get 20k out of them but, no luck. I drove 80% conservative and 20% bonzai, fwiw. I replaced them with Nitto Invo's. I hope they last 20k or more.
dcarlinf1 is offline
Old 05-14-2012, 12:11 PM
BKamp613
BKamp613's Avatar
I'm pushing 28k on my all-seasons. 11k was by me, the other 17k was from the original owner.
Need to get new ones...
BKamp613 is offline
Old 05-14-2012, 12:53 PM
REDBOSS1
REDBOSS1's Avatar
Originally Posted by JimC
Something doesn't sound right - I had the Pzero Nero on my car in the 17" size and was getting 50 - 60,000 on them (I have 202,300 on this car, and just recently put the Nitto Motivo on, a great tire by the way so far).
The Pzero's aren't a summer only tire as far as I know and 16K on them is really low.
The P-Zero is an all summer tire, it states right in my manual to not drive in temperatures under 40 degrees, most guys are getting about 15-20k on them. I think a lot of you guys are confusing them with the P-Zero Nero that run about $200, the P-Zero are about $450 a pop.
REDBOSS1 is offline
Old 05-14-2012, 01:16 PM
99gtstang
99gtstang's Avatar
220 Treadwear - not good for much. The P-Zero summer tires that came on my Brembo are great for traction, but $356 a piece is HIGH.
99gtstang is offline
Old 05-14-2012, 03:26 PM
danman0469
danman0469's Avatar
Yeah, $1600ish for 10-15k miles... when mine are worn, I won't be replacing them with another set of P-Zeroes. They are great tires though. You have to try to spin them. That's pretty incredible to me, with 412 hp on tap.
danman0469 is offline
Old 05-14-2012, 07:24 PM
MrSandman
MrSandman's Avatar
I got around 15,000. I replaced them with Michelin Pilot A/S plus...and couldn't be happier! Well worth the $$ for my daily driver.
MrSandman is offline
Quick Reply: stock p zero tires worn out after 16K miles
