Overheated - Page 3 - MustangForums.com
Old 08-21-2013, 11:31 AM   #21
ski
The fan's ground connection may be corroded, which can cause the fan to intermittently stop running.
If cleaning any corrosion from the fan's ground connection does not solve the problem, then start the engine, and turn on the A/C. This will cause the fan to run continuously. If it runs continuously and the engine does not overheat, then the fan's high speed circuitry components and the engine's cooling system components are ok.
If the fan does not run(or runs intermittently) with the A/C on, then one of the following is causing the problem: bad fan motor, bad high speed relay, bad/loose high speed electrical contact in the connector on the side of the fan shroud(or somewhere else in the high speed electrical circuitry), or a bad high speed PCM component.
If the fan runs continuously with the A/C on, and the engine does not overheat, then turn off the A/C and keep the engine running. If the fan does not come on(or it runs intermittently), then one of the following is causing the problem: bad low speed resistor(built into the fan shroud), bad low speed relay, bad/loose low speed electrical contact in the connector on the side of the fan shroud(or somewhere else in the low speed electrical circuitry), or a bad low speed PCM component.
ski is offline   Reply With Quote
Old 08-21-2013, 03:45 PM   #22
Derf00
Quote:
Originally Posted by V8 VOL View Post
This weekend when I dive into this project I will take note and check everything mentioned in the last few posts. I appreciate the videos and the feedback. Hopefully I can get this nailed down and find out the exact cause of my issues this time.
I did check the G100 ground last night and it was tight.
Good luck and keep us posted!
Derf00 is offline   Reply With Quote
Old 08-21-2013, 05:22 PM   #23
hootie_john
hootie_john's Avatar
Isn't this a pretty common problem on the S197? Something about a short in the fan housing/resistor or something along those lines?
hootie_john is offline   Reply With Quote
Old 08-22-2013, 12:39 PM   #24
Derf00
Quote:
First I've heard about it...? Living in AZ I would think it would be old news to me if that were the case.
Battery's dying in a couple years...yep, get that all the time. On my 4th one right now in 5 years.
Old 08-22-2013, 02:16 PM   #25
wcgman
wcgman's Avatar
I havent heard of it being common place either in the 197. The previous gen yes. It would melt right at the fan and then no fan... Had that happen twice.
wcgman is offline   Reply With Quote
Old 08-22-2013, 04:48 PM   #26
moosestang
I'd remove that ground and sand the paint underneath, just for good measure.
someone else had a problem with the fan and the underside of the fuse box was shorting out, so life up your fuse box and check it.
moosestang is offline   Reply With Quote
Old 08-25-2013, 03:29 PM   #27
V8 VOL
V8 VOL's Avatar
I found the problem. This is underneath the high speed fan relay. Does anyone know the part number for the fuse block this is connected to? I have done some searching but came up with nothing. Any helpful info on making this fix would be highly appreciated as well.
V8 VOL is offline   Reply With Quote
Old 08-27-2013, 05:05 PM   #28
Derf00
http://www.fordparts.com/Commerce/Ca...Mustang#Search
Looks like the Fuse Box Retainer (PN 14536) or in the general vicinity. I'd find out what caused that melt down before just replacing. That's not typical unless the relay shorted out internally.
Old 08-28-2013, 11:00 AM   #29
V8 VOL
V8 VOL's Avatar
Unfortunately it looks like the part I need only comes as part of item 14A068A for $300 ($200 at Tousley). I am going to hit the junkyard next weekend and see if I can get a hold of just the plastic part I need.
From my research it looks like this could have been caused by running my fan speeds at too low of a temp. I have a 170* thermostat and had the fans set at 180 Low 186 High.
Once I get this fixed I am going to run them at 185/195 in case that was the issue. My goal is to keep the temps below 200. At the prior setting I was hanging around 195-197.
Old 08-28-2013, 05:06 PM   #30
Derf00
Ah that sucks ($200+) have you checked e-bay? My daughter recently inherited my wife's 06 Ford Escape and I've had to replace a whole mess of parts like the sunroof frame, cowl vent panel, both sun visors, and e-bay saved me a ton of cash so far.
I'm sure if you find a wrecked mustang online and show exactly what part you need they'll pull it for you for probably Less than $50-$75 shipped. It's not a wear item so new or used should make no difference as long as it's not fried like yours.
Finally drove 2015 Automatic w/ Ford Racing Handling Package, very nice. mungodrums The New S550 2015-2016 Mustang 7 09-29-2015 10:18 PM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 12:10 PM
All 10-14' Mustangs w/ Sync Raxiom Navigation Unit - Not Working - yourmom6990 Parts For Sale 2 09-14-2015 11:52 PM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 08:05 AM
96 V6 Gauges (Temp) 96stang3.8 V6 (1994-2004) Mustangs 1 09-10-2015 07:42 AM
170, 2007, bama, cai, car, causing, coolant, forum, gt, hissing, install, mustang, overheat, stupidcams, tampacraigslist, thermostat, tune
