Sponsored by:
Sponsored by:
Need Help
Old 05-21-2012, 10:34 AM
James07GT
James07GT's Avatar
Default Need Help
I was removing my axlebacks and everything was going good till I got to the last 13mm bolt on drivers side. It will turn in both directions but it doesnt seem like its tightening or loosening.
James07GT is offline
Old 05-21-2012, 10:44 AM
xkape
xkape's Avatar
whats on the backside? If there's a nut on there you could use a wrench to hold it in place while you unscrew the bolt.
xkape is offline
Old 05-21-2012, 11:15 AM
James07GT
James07GT's Avatar
theres nothing on the backside, last time I removed them I didnt have this problem. Theres no room for a wrench theres only a small hole you can stick your finger threw but you can feel the end of the bolt.
Old 05-21-2012, 11:23 AM
xkape
xkape's Avatar
so its just spinning in place with nothing holding it in. That's kinda odd. The next thing I would try then is pulling down on the bolt hard while trying to unscrew it.
xkape is offline
Old 05-21-2012, 11:37 AM
James07GT
James07GT's Avatar
Im confused cause its the only bolt holding the muffler in place. Ive been trying all morning lol. I didnt try pulling down on it but I did try pushing up on it and unsrewing it and its not tightening or loosening just turning forever.
Old 05-21-2012, 11:41 AM
xkape
xkape's Avatar
Yeah I would just pull down and turn it to try and get it out of there. But, something is stripped so putting it back on probably won't result in a tight fit. New part needed perhaps?
xkape is offline
Old 05-21-2012, 11:52 AM
James07GT
James07GT's Avatar
if so it would be a 13mm bolt for the exhaust hanger.
Old 05-21-2012, 01:48 PM
CPTCO
CPTCO's Avatar
Angle grinder, cut off tool, hacksaw blade, whatever will fit. Probably a carriage head bolt that has turned and ruined the square slot it fits into. You might mess with it all day, just cut it and start over.
CPTCO is offline
Old 05-21-2012, 04:09 PM
James07GT
James07GT's Avatar
I dont have any of those tools lol and im not even using jack stands or ramps. I took a break but im going to try again. Out of those tools which would be the cheapest and just in case where would I find more 13mm bolts for the hangers.
Old 05-21-2012, 05:14 PM
James07GT
James07GT's Avatar
so i manged to get the muffler out even with the 13mm bolt still holding the hanger in now all thats left is to see what i need to do to get the bolt out.
