Sponsored by:
Sponsored by:
2007 Convertible Frame BENT! HELP!
Old 05-25-2012, 12:01 PM
OurOwnWars
OurOwnWars's Avatar
Unhappy 2007 Convertible Frame BENT! HELP!
I have a 2007 Mustang convertible and the frame for the convertible top is BENT!
Here is the driver's side, it's good:
Here is the passenger's side, it's not good:
2005-2011 All take the same top. I've been calling junk yards for days and NO ONE has a convertible top frame for my car! I really really really don't want to buy an OEM frame. I'd much rather find a used one or even an aftermarket one and I'd rather buy that component vs. a whole frame if that is possible.
Or can I have someone take it out and bend it back into shape? I'm pretty sure it bent because it was way overdue to be lubricated... like, it bent when I was opening it up.
OurOwnWars is offline
Old 05-25-2012, 12:27 PM
S197GT07
S197GT07's Avatar
Overdue to be lubricated? What?
I've had my vert since 07, and never had that issue, or heard about it. Also, that steel is decently thick, it can't just bend like that. You sure its not just disconnected on the mounting side, or came out where it connects to the top?
S197GT07 is offline
Old 05-25-2012, 01:52 PM
OurOwnWars
OurOwnWars's Avatar
It's still attached (firmly) at both ends. It's very bent. From the outside it looks like someone was body slammed onto the rear corner on that side. The top cross-bar itself isn't bent, just that arm there. Honestly, I have no idea why it bent. I was trying to put the top up and it acted like it was stuck, then it gave on that side. the other side acted fine though.
Old 05-25-2012, 04:37 PM
OurOwnWars
OurOwnWars's Avatar
The part that is bent is part # 53104A
Here's a side shot of the driver's side
Here's a side shot of the passenger's side
Old 05-25-2012, 07:16 PM
Goldenpony
Goldenpony's Avatar
Any idea at all how this happened?
Goldenpony is offline
Old 05-25-2012, 07:45 PM
SD 197
SD 197's Avatar
Is it possible that the car could have been vandalized? Maybe some big drunk dude slammed into the side of the top one night, and you didn't notice it?
If so, then it could be an insurance issue.
SD 197 is offline
Old 05-21-2018, 05:48 PM
steven010
steven010's Avatar
Top gets bent due to low fluid in pump. One ram has fluid, one does not. Also manually trying to force down will bend it.
steven010 is offline
cr620
10-03-2022 10:18 PM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
folivier
10-02-2015 05:34 AM
guitarman376
09-30-2015 05:54 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: 2007 Convertible Frame BENT! HELP!
