2006 mustang v6 coolant leak, NOT water pump - MustangForums.com
Old 10-23-2015, 02:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
Old 06-17-2012, 10:13 PM   #1
Jason Hull
Angry 2006 mustang v6 coolant leak, NOT water pump
So, I've got a 2006 mustang v6 that is leaking coolant from somewhere along the bottom passenger side. It's not the water pump (I just finished replacing that). It's also not the thermostat housing (no water coming from around there).
Is it possible that the timing chain cover sprunk a leak? When it runs, it's a very rapid dripping, and when off, it drips more slowly for a while, eventually mostly stopping.
No water in the oil that I've noticed so far.
Let me know what your thoughts are... THANK!!!
Here's a picture from below...
http://guywmustang.com/upload/MustangCoolantLeak.jpg
Jason Hull is offline   Reply With Quote
Old 06-17-2012, 11:41 PM   #2
Jason Hull
Here's a smaller version of the picture. Anyone know where the freeze plugs are on a 2006 Mustang v6 engine? Maybe one of those?
Old 06-18-2012, 09:14 AM   #3
kevinmalec
kevinmalec's Avatar
It's most likely a cracked upper or lower thermostat housing. They are made out of hard plastic and this is very common in the 05' & 06' V6 models. Also, the Ford Escape has the same issue. Mine has a slow leak as well. Next on my list to get fixed!
kevinmalec is offline   Reply With Quote
Old 06-18-2012, 10:49 AM   #4
2005Redfire6
Quote:
+1 I'd check the thermostat housing.
2005Redfire6 is offline   Reply With Quote
Old 06-18-2012, 12:55 PM   #5
Jason Hull
Leaky head gasket... ouch.
Old 06-18-2012, 02:19 PM   #6
2005Redfire6
That sucks and I've never really heard of that on these motors, but hey at least you know what it is now.
Old 06-18-2012, 04:41 PM   #7
kevinmalec
kevinmalec's Avatar
Yeah, that does suck..........
How much will it cost to fix?
Old 06-18-2012, 05:10 PM   #8
Jason Hull
Turned out it was the thermostat housing... so hard to see the water leaking up there... but when we jacked it up, the water ran out from the back as well as the sides, so figured it couldn't be the head gasket.
Those thermostat housings are a bad idea...
We had a hint when the Ford dealer said that their technician with 30+ years experience has never seen a head gasket leak from the front on these engines.
So, it cost $100 to fix instead of many $100s
Thanks all
Old 06-18-2012, 07:10 PM   #9
Nuke
Nuke's Avatar
See? The forum members know ALL! Stick around for MORE helpful (and cheaper) repairs.
And welcome.
Nuke is offline   Reply With Quote
Old 06-19-2012, 12:09 PM   #10
kevinmalec
kevinmalec's Avatar
Thanks all
Good to hear!!
The dealer fixed it for $100 or did you fix it yourself?
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 01:55 PM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 02:02 AM
Original Owner 1970 Mustang b8checker New Member Area 3 09-30-2015 08:11 AM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
Fuel Pump for 98 3.8L model. Not sure which type? mrappe V6 (1994-2004) Mustangs 0 09-26-2015 11:16 AM
