Used 09 GT - how can I get original window sticker?
I bought a used 09 GT and the dealer I got it from did not have any of the car specifics. Is there some way I can find out the original equipment on the car as delivered back in 08?
There are a few things on/in the car that Im not sure if they are factory installed or aftermarket (i.e. Serius satellite radio antenna, etc..)
Ideas?
Thanks,
Walt
Ideas?
Thanks,
Walt
Add your vin number after the = sign and you will get your window sticker. Click the link and add your vin number in the address line. You'll see your factory sticker and you can print it out. Good luck.
http://services.forddirect.fordvehic...icker.pdf?vin=
Walter
Very cool to look at, thanks for sharing akdoggie.
this is friggin legit!!!! THANKS!!!!
people having problems follow above steps. as soon as u copy paste at the end it says vin=
This is where you enter YOUR VIN. other wise you will get that error message. Hope this helps
