Sponsored by:
Sponsored by:
Really beginning to hate this car...
Old 07-16-2012, 04:25 PM
Jas5
Jas5's Avatar
Originally Posted by MiniD
What is the "TB"?
throttle body.. it's on the middle top of motor, where the air enters. Must remove the opposite end of your airbox tube, the part connected to the motor, to see/clean it. Inside of this is a flap or valve, opens when you press on the gas, closes when you are not giving gas
Jas5 is offline
Old 07-16-2012, 04:37 PM
wcgman
wcgman's Avatar
It can also make your car die at idle if it's really nasty
wcgman is offline
Old 07-16-2012, 04:46 PM
Young_Gun
Young_Gun's Avatar
Well, the guy that had the car before me was British, and didn't seem to know much about cars.
I'll be checking everything as soon as it cools off this evening.
Just glad I was able to limp home and pick up another car before going back to work.
I do have a new CAI. Maybe something from that got in the TB...
Young_Gun is offline
Old 07-16-2012, 05:14 PM
Tom V
Tom V's Avatar
What is the "TB"?
"Throttle Body". Memorize it. You will see TB often on the forum.
Tom V is offline
Old 07-16-2012, 05:17 PM
mayo
mayo's Avatar
The plot thickens...
mayo is offline
CAR-15
CAR-15's Avatar
Also, Since you just put on a new CAI you need to check and see if the MAF is gunked up from the oil on the air filter. I would clean the MAF, the TB and go from there.
CAR-15 is offline
Old 07-16-2012, 05:57 PM
Young_Gun
Young_Gun's Avatar
Wouldn't a gunked up MAF affect the way the car drives?
Old 07-16-2012, 06:07 PM
Tom V
Tom V's Avatar
Do both, you will basically have it apart anyways.
Tom V is offline
Old 07-16-2012, 06:10 PM
Nuke
Nuke's Avatar
Did you check with your tuner to see if your tune needs to be updated for the new CAI?
The crankcase oil has nothing to do with your idle problem. In addition to the TB cleaning and fuel filter replacement, I'd run THE PROPER MIX of SeaFoam thru the fuel system to help POSSIBLY rule out a dirty injector (unless the injectors are really FUBAR).
Nuke is offline
Old 07-16-2012, 07:45 PM
CAR-15
CAR-15's Avatar
This, that was my thought. Clean it all while you have it all apart.
CAR-15 is offline
Quick Reply: Really beginning to hate this car...
