Really beginning to hate this car...
#22
#23
Find thread throttle body cleaning. Sorry, I don't know how to link it. There is a good video that shows how to do it. Just a little added input. Loosen all 4 bolts to the throttle body, then take them out one at a time. If you loosen and remove one at a time when you loosen the last bolt you could mess up the gasket. Ask me how I know.
Make sure you use the crc throttle body cleaner. Use MAF cleaner for the MAF. Be careful of the MAF. It wouldn't take much to mess it up.
#27
Maybe they talked about that in the video, but I didnt watch it.
#28
I cleaned the MAF and the TB. Man, there was a ton of gunk in the TB. Now the idle is high (it did drop back to normal after about 5 minutes). Its throwing two lean codes, but I'm going to reset with the battery and then reflash the PCM with the tuner
#29
It ran fine till this afternoon. The idle was unstable again. I was getting lean codes again. My CAI had popped loose a bit. I reattached it and reflashed the ECU. Doing the fuel filter tomorrow afternoon.
