Sponsored by:
Sponsored by:
Really beginning to hate this car...
Old 07-16-2012, 10:43 AM
Young_Gun
Young_Gun's Avatar
Default Really beginning to hate this car...
Its going in the shop... Again... It was fine this morning but when my manager sent me to the store, it was dying at idle. Any time it wasn't idling, it was fine. Even sounded fine. Wasn't even overheating.
I hate this.
Young_Gun is offline
Old 07-16-2012, 10:57 AM
Nuke
Nuke's Avatar
Apparently, I haven't been following prior threads, if any, on your issues. Wuz up? From your description, I can only assume an idle issue and I KNOW that YOU KNOW to clean the TB first for that single issue. Anything else?
Nuke is offline
Old 07-16-2012, 11:06 AM
Sethman29
Sethman29's Avatar
Need a new fuel filter?
Sethman29 is offline
Old 07-16-2012, 01:13 PM
Lil_Chef
Lil_Chef's Avatar
sounds like the exact problem i had when i forgot to completely close my airbox...
Lil_Chef is offline
Old 07-16-2012, 01:52 PM
jdmcbride
jdmcbride's Avatar
When was the last time your replaced your fuel filter? If it has been awhile, that is a cheap fix that you probably need to do anyway.
jdmcbride is offline
Old 07-16-2012, 02:54 PM
Young_Gun
Young_Gun's Avatar
Cleaning the TB tonight, checking the fuel filter tomorrow. The greens superintendent at work (I work at a golf course) said I should check for a gunked up injector, so if the first two don't work I'll try that.
I'm also due for a 5000 mile oil change as of 100 miles ago. Could that have something to do with it?
Old 07-16-2012, 03:19 PM
t_kurgan
t_kurgan's Avatar
If you're going to do an oil service, you may want to run a couple of bottles of Techron concentrate through two subsequent tanks to help clean the internals, it's a cheap try anyway.
t_kurgan is offline
Old 07-16-2012, 03:20 PM
SchneidyP4.6
SchneidyP4.6's Avatar
Going 100 miles over on the oil change will not harm your car/cause these issues! You might have a bad MAF(mass air flow sensor)...
SchneidyP4.6 is offline
Old 07-16-2012, 04:02 PM
BleedinBlue
BleedinBlue's Avatar
The oil change is irrelevant.
The TB, however is the FIRST thing you should have checked. It's the first place you want to start with idling issues with these cars. Clean it, then air filter, then fuel filter.
C'mon man!
BleedinBlue is offline
Old 07-16-2012, 04:15 PM
MiniD
MiniD's Avatar
What is the "TB"?
MiniD is offline
Quick Reply: Really beginning to hate this car...
