Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Jump Start Battery
Step by step instructions for do-it-yourself repairs
Battery or alternator?
Then I went to autozone and they tested me doing a start up and said everything checked out.
But after work today I had to get jump started by a stranger. This time I took it inside autozone and had them bench test it, they said it was BAD!
So I got a 3 year Duralast today. Get this, the old battery was a 3 year duralast as well (gold), and had 12/10 on it, so only 1.5 years old. However I didn't have the original purchaser's phone # so didn't get a free battery.
edit: ok this sounds really noob, but if you unplug the negative and let the ECU reset, or say replace your battery, does your tune stay the same? Mostly curious cause my idle keeps dropping to 550 rpm for a few seconds, then raises back to 750, when I go to neutral and it makes me nervous. I do not have a handheld tuner or anything.
Well O'reilleys hooked it up to their machine inside and it tested "good"
Wherever you took that battery they should have given you the warranty regardless. That's why the date sticker is on the side. We'd have people come in and we'd ask but if it wasnt in the system or they didnt have a receipt, we'd go off of the date sticker and either they would get a new battery or a prorated one. Only once did we send someone packing and that was because the battery clearly had physical damage which is not covered under any warranty.
I am telling you that this may be exactly what it needs. I solved this issue a few months ago on one of my cars.
That's just it... the battery probably isn't bad, just drained. It won't die again if you charge it properly. If your alternator was bad then your car wouldn't be running.
Just jumping it off is not enough to fully charge it. Your car is starting because someone else's battery is doing the work. Your car is running because the alternator is powering the car. But, in order to crank the car again, you need to have your battery fully charged. This won't happen by just letting the car run for a few hours... That's why you have to keep having people jump start your car for you. The battery is drained, and charging it overnight will give it that deep charge it needs.
By the way, I am an Electrical Engineer.
I mean if either the battery or alternator are bad, it will end up just dying again.
If he has that old OEM battery then sulfation alone has probably weakened the output of the battery at the terminals. Not to mention, a battery will degrade over time and no longer hold charge as well as it used to (chemical breakdown I believe). Better to just replace the battery all together IMO.
If I was dealing with the original battery from 2007, then yeah, I would probably replace it too when it became convenient.
I was explaining why I recommended the trickle charge... most people don't understand that you can't just jump a dead battery, run it for 10 minutes, and expect it to magically charge all the way up.
