Sponsored by:
Sponsored by:
Rear suspension squeak
Old 08-27-2012, 11:54 PM
09cs
09cs's Avatar
Default Rear suspension squeak
I got a squeak coming from the rear suspension any time I'm doing 30+ over any bump. I looked under, and everything seems to be in order, so not sure what this could be, any suggestions?
09cs is offline
Old 08-28-2012, 09:36 PM
09cs
09cs's Avatar
bump, anyone?
09cs is offline
Old 08-28-2012, 09:44 PM
Menace
Menace's Avatar
Suspension all stock? I know the Lower Control Arms have a tendency to squeak a lot, but your bump/speed specific squeak .. I dunno.
Menace is offline
Old 08-28-2012, 11:12 PM
05gtdriver
05gtdriver's Avatar
Exactly, what are your mods? On my last GT(the 2006) I had Roush springs and an Edelbrock Panhard rod(adjustable & greasable). When the grease would run low, it squeaked & rattled a bit. I'd top off the grease, and viola, like new again. If you've made changes, that's where you need to inspect 1st. Good luck
05gtdriver is offline
Old 08-30-2012, 12:30 AM
09cs
09cs's Avatar
Only suspension mod is Eibach pro kit
09cs is offline
Old 08-30-2012, 02:15 AM
05gtdriver
05gtdriver's Avatar
Maybe that rear spoiler? That's a heavy piece(compared to stock) maybe it's the reason for the squeak? If you only have springs installed, maybe the isolators aren't up to snuff anymore. I'm just guessing at what it might be, but usually start with any mods you've made to deduce what it could be faster. Best of luck!
Old 08-30-2012, 06:44 AM
Menace
Menace's Avatar
Yeah, recheck your current mods and depending on how old/many miles the car has the suspension parts might need a good lubing to prevent things like this.
Menace is offline
Old 08-30-2012, 11:22 PM
09cs
09cs's Avatar
The springs I've had on for probably 15-20k miles.
09cs is offline
Old 08-31-2012, 10:29 AM
illini4
illini4's Avatar
Lower control arms. To confirm, shoot some WD-40 or something similar into the bushings - if the squeek stops, that's your problem. You can get a replacement set with hardware from American Muscle for $125 or so. Replacement is fairly easy if you have jack stands and the tools.
illini4 is offline
Old 08-31-2012, 11:41 AM
BleedinBlue
BleedinBlue's Avatar
That is my guess as well.
If the WD40 stops the squeak, grease up the bushings on the control arms. If you can, it'd be a good time to replace the LCA's since you'll be taking them off anyway.
It's a tight area to torque the bolts to the requirement, but it really is as simple as removing and replacing two bolts for each side.
BleedinBlue is offline
Quick Reply: Rear suspension squeak
