Sponsored by:
Sponsored by:
2 month and couldn't fix my problem, can someone help please
Old 09-04-2012, 10:49 AM
  #31
Maraman
Maraman's Avatar
Is there a chance that the fuel system could have become contaminated?
Try flushing the entire fuel system and swapping out the injectors for new ones.
Maraman is offline
Old 09-04-2012, 11:35 AM
  #32
Roy_R
Roy_R's Avatar
Wow, so just a bad connection on the FPDM, glad you figured it out!
Roy_R is offline
Old 09-04-2012, 12:29 PM
  #33
moosestang
moosestang's Avatar
Originally Posted by Tony_m
After all that pain for 2 month i found 1 used FPDM for a 06 Stang in my country, i stayed awake and ran to try it now.
I installed the 06 one and went for a ride and the problem was exactly the same so i was disappointed.
I re-installed MY FPDM, WOT the car in park mode and it reached the 6000RPM till rev.
I drove the car and couldn't wait to reach an open road, took it up a small hill road and i was surprised! the car ran perfect with not a single fault!
Now what the hell was this headache for 2 month? What happened when i switched the FPDM knowing that yesterday i removed mine from the trunk and cleaned its connectors + its back. Did the used FPDM reset to the PCM or what?
Now shall i buy and ship a new FPDM? Shall i do something else to keep it running?
How do the connectors look? any corrosion? If there was an internal problem with your fpdm, then the used one should have worked.
moosestang is offline
Old 09-05-2012, 04:50 AM
  #34
Tony_m
Tony_m's Avatar
The used one didnt work, it was mine that worked after the switch i did, no corrosion the car has perfect body like new.
Im gonna reinstall the JLT and race tune let see how things will go.
Tony_m is offline
Old 09-05-2012, 07:38 AM
  #35
Stang8URMPRT
Stang8URMPRT's Avatar
So much bad diagnostic information here, it's incredible. A Throttle body problem because of a voltage drop to the pump? And no fuel pressure?? MAF problem because of the same issues? Replace this part, replace that part... Come on guys! Who has the money to just throw parts at a car hoping it will fix it??? lol.
I am very glad you figured it out, Tony_m. The connector probably wasn't seated properly or had a small amount of corrosion in it. Make sure to clean the connector and put some dielectric grease in there to keep it from happening again.
Stang8URMPRT is offline
CMcNam
10-30-2022 11:40 PM
drfister
05-03-2018 10:38 PM
FD725
08-23-2015 06:43 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: 2 month and couldn't fix my problem, can someone help please
