Sponsored by:
Sponsored by:
07 GT Auto shifter
Old 09-15-2012, 12:40 AM
Tang 72
Tang 72's Avatar
Default 07 GT Auto shifter
So have an 07 GT Premium with the silver automatic silver lever cover and it is malformed at the top along the seam where the two halves snap together. While functionally this does not matter, the feel bothers me. Is the silver lever/shifter cover just snapped on over the stock black casing or does it replace it entirely? i could just make a cover for it out of vinyl it the piece is important and not just cheap dress-up, but would prefer not to have to.
Tang 72 is offline
Old 09-15-2012, 08:45 AM
mayo
mayo's Avatar
Ah yes the auto shifter, what a POS.
Hmm, ok its like when the guy tells Joel in one of my favorite movies of all time, Risky Business...
Sometimes you gotta say "what the f&ck", and make your move.
If you can't say it...you can't do it.
You will need to be in this mindset to use the following link...
http://www.americanmuscle.com/tci-ra...adtype=pla&kw=
mayo is offline
Old 09-15-2012, 09:35 AM
Tang 72
Tang 72's Avatar
Looks like ill have to get creative with this one. No way im spending 500.00 on a giant ratcheting shifter... Ill probably make a cover for it and be done with it.
Tang 72 is offline
Old 09-15-2012, 02:24 PM
808muscle
808muscle's Avatar
Wow did they have a price increase. When I bought mine they were around $325 or so. FWIW, its not a giant shifter. The quality, feel and performance is as good as it gets. Worth every dollar IMO.
Attached Thumbnails 07 GT Auto shifter-003.jpg   07 GT Auto shifter-010.jpg   07 GT Auto shifter-2012-02-04_15-40-12_289.jpg
808muscle is offline
Old 09-16-2012, 08:44 AM
pinn
pinn's Avatar
The silver piece can be removed very easily, but good luck finding a replacement. I think the entire assembly is a single part #, may want to hit up junk yards for just the trim pieces.
I took mine apart to fix the small plastic strip that lets you know which gear you are in. There are 4 plastic snap-tabs that secure it to the shifter assembly.
Edit: if it is just the shifter itself, a single recessed screw on the front holds this in place. it is also very easy to remove.
pinn is offline
Old 09-16-2012, 08:50 AM
aero86
aero86's Avatar
im just wondering how bad shifting it manually would be often?
aero86 is offline
Old 09-16-2012, 08:51 AM
pinn
pinn's Avatar
https://mustangforums.com/forum/gt-s...r-install.html
Good thread that shows how to access the assembly.
pinn is offline
firehorse02
11-16-2015 11:28 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: 07 GT Auto shifter
