Sponsored by:
Sponsored by:
50,000 miles, now what?
Old 09-30-2012, 07:48 PM
ThaiCobra
ThaiCobra's Avatar
Default 50,000 miles, now what?
So my 2007 GT is about to hit 50,000 miles.
What kind of check-up / maintenance do you guys recommend?
Should I go by the dealership maintenance shop?
ThaiCobra is offline
Old 09-30-2012, 07:53 PM
baddog671
baddog671's Avatar
What maintenance have you done already, as far as fluids and filters go?
Sparkplugs would be a good consideration at this point...
baddog671 is offline
Old 09-30-2012, 09:50 PM
ThaiCobra
ThaiCobra's Avatar
other than regular oil change and oil filter, nothing at all.
Old 09-30-2012, 10:10 PM
ThaiCobra
ThaiCobra's Avatar
I was thinking of just asking the Ford dealership what they recommend for 50k Mustangs, but I do not want to get robbed...
Old 09-30-2012, 10:21 PM
mth21305
mth21305's Avatar
IF the fluids havent been changed in a while (diff, coolant, tranny) i would do that as well as the cabin air filter and airbox filter if you dont have a CAI, and definatly spark plugs. But im a little picky with my vehicles so i might be over doing it a bit. Also check your recommended maintenance schedule and see what it says.
mth21305 is offline
Old 09-30-2012, 11:08 PM
07BLACKGT
07BLACKGT's Avatar
Hrm, how necessary is changing the spark plugs at 50k? I'm at 69k now sooo I'd say it's time?
07BLACKGT is offline
Old 10-01-2012, 12:50 AM
HxCGuitars
HxCGuitars's Avatar
With the old style heads, I'd say yes
OP, I'd drain and flush the coolant system, change out the fuel filter, air filter, cabin air filter, and consider doing your rear end fluid and possibly the trans fluid. Other than that and spark plugs, I'd say you're good to go!
HxCGuitars is offline
Old 10-01-2012, 09:35 AM
smokievol
smokievol's Avatar
Doing the fuel filter and trans fluid every 30,000. Just did the rear end and it made a big difference in the noise, went with redline. The trans fluid also makes a difference in the noise I was hearing from the car.
Most important up keep is to add a Super Charger!!
smokievol is offline
Old 10-01-2012, 12:26 PM
808muscle
808muscle's Avatar
Don't go to the dealer, do all that stuff yourself.
808muscle is offline
Old 10-01-2012, 12:39 PM
Roy_R
Roy_R's Avatar
You are lucky, if you had bought a BMW, the **** would start now!!!
Roy_R is offline
Quick Reply: 50,000 miles, now what?
