clutch or transmission
this is starting to happen alots:
drive around, get to a stop or a light, first gear, full feet-pression on clutch, rpm will bounce and either want to die(like if the clutch wasnt correctly engaged) or the car will slowly try to move forward so I gotta put bigger pressure on break, it like if I was half way clutch release ready to move...I dont feel anything weird while pushing the clutch, but the car react like if my feet wasnt fully on it...any idea? man my transmission is about to die with all the bearing I hear making noise, cant believe my ****ing clutch is about to go too? argh
oh and sometime my shifter is stock in my gear, like already said in another post, cant get my freaking gear out without pulling HARD on the shifter.
Check your clutch fluid not brake fluid.
There is no stick for the auto trans either. Look in your owners manual if you have one. My car didnt come with one, but no matter...... my car now has a trans dipstick! LOL
Are you leaking fluid from behind your clutch inspection plate? If so that is the slave cylinder. Showing signs of a clutch problem some where, although maybe not the clutch itself. You need to check your slave master cylinder resevoir. I do not know if the brakes & clutch pull fluid from the same resevoir. The bright side of it is that if your are fixing to have to pull the transmission your right there any way.
I must be blind, i dont see any clutch fluid tank
crap nevermind, found it, already was aware of that tank but wasnt sure if it was break or clutch fluid, all my tank fluid are half way between max and min..doesnt seems like the problem
gotta check my tranny oil in case...
