white smoke after start up
this morning started the car just to move it since it was in the way then shut it off. tonight when i started it white smoke came out the mufflers is this normal? i went for drive everything seems normal.
White smoke is moisture. You'll get some from normal overnight sitting. It will increase when you heat those pipes early in the morning, but not long enough to burn off present condensation. More moisture will collect, and then when you start it later, you'll get the smoke again.
Wouldn't worry about it.
