Sponsored by:
Sponsored by:
07 GT500 Clutch Failure at 20,000mi
Old 11-02-2012, 01:03 PM
04AZUREBLUEMACH1
04AZUREBLUEMACH1's Avatar
Default 07 GT500 Clutch Failure at 20,000mi
I've only driven this car 6,000 miles (no racing, just street) and I think the clutch is acting up... When I'm cruising at around 40mph in 5th gear, if I floor it, the revs jump really high and no power goes to the wheels; it's like the car is in Neutral. I was told by other Mustang enthusiasts that this is a sign of the clutch getting ready to go out.
Does this sound correct? If I do get my clutch replaced (it's under warranty), is there a better clutch from FRPP that I should pay to have installed?
A buddy who works for Ford nearby told me not to mention my tune to them... I agree, as I don't see why they'd want to read or flash the computer while diagnosing the clutch, but who knows. What are your experiences with warranty claims and modifications? I'm not sure if they could realistically say that my pulley/CAI/tune caused my clutch failure unless they're going to accuse me of racing.
As always, thanks.
04AZUREBLUEMACH1 is offline
Old 11-02-2012, 01:55 PM
kevinmalec
kevinmalec's Avatar
There are a couple of different ways to check if your clutch is slipping. Take the car for a drive. See if it takes more RPMs from the engine to achieve the right speed. This can also be an indicator your car needs a clutch replacement. While driving down the road in 2nd gear, put the car in 3rd or 4th gear then let out the clutch. If the RPMs of the engine go up, but the speed of the vehicle does not, it is time to replace the clutch.
Another way to establish if your clutch needs repair is to test it in a parking lot. With it stopped but running, put the car in 2nd or 3rd gear and let out the clutch. If it does not stall, but the RPMs go up and the vehicle does not move, the clutch is bad and needs to be replaced.
http://www.ehow.com/how_7687_diagnos...ng-clutch.html
My Slave cylinder/Throwout bearing went out at 65K miles. I had a 2-3 inch dead spot at the top of the clutch pedal and I could barely put my gear shifter into any gear.
kevinmalec is offline
Old 11-02-2012, 02:13 PM
moosestang
moosestang's Avatar
The previous owner could have had it at the track every weekend launching on slicks!
Is your car stock? If the revs increase and the mph don't, then that's a sure sign that the clutch is slipping.
moosestang is offline
Old 11-02-2012, 02:48 PM
aaquib1992
aaquib1992's Avatar
I remember reading somewhere about a very common clutch TSB for the GT500s, if you're not familiar with it you might want to read up on that before you take it in.
It doesn't sound like you have the symptoms of that TSB problem, but better safe than sorry. Here's a link to the TSB.
aaquib1992 is offline
Old 11-02-2012, 03:17 PM
Andy13186
Andy13186's Avatar
do the gt500's have a hydraulic or cable clutch?
Andy13186 is offline
Old 11-02-2012, 03:43 PM
kevinmalec
kevinmalec's Avatar
I'm pretty sure the GT500 has a hydraulic clutch.....
Old 11-02-2012, 03:46 PM
Roy_R
Roy_R's Avatar
Pretty sure your clutch is toast...and that TSB above doesn't apply, cause it's for the clutch engaging when depressed.
Take it in, tune shouldn't be an issue, but you never know these days.
Roy_R is offline
Old 11-02-2012, 03:55 PM
GrayPony
GrayPony's Avatar
Why are you doing 40mph in 5th? With a small SC pulley and the added torque, lugging the engine like will take it's toll on the clutch. The clutch is "wear and tear" and not warranty.
GrayPony is offline
Old 11-02-2012, 05:10 PM
moosestang
moosestang's Avatar
They aren't likely to cover a worn out clutch.
Old 11-02-2012, 05:38 PM
modru2004
modru2004's Avatar
lol what.
40 mph in 5th isn't lugging the engine.
but ya clutches aren't warranty items.
however if you have a service plan wear and tear items are included, yes this means the clutch as well except for tires. tires are the only thing thats not included.
modru2004 is offline
Quick Reply: 07 GT500 Clutch Failure at 20,000mi
