Sponsored by:
Sponsored by:
Pipes X pipe
Old 11-15-2012, 07:49 AM
jbodak31
jbodak31's Avatar
Default Pipes X pipe
Has anyone put a pipes X pipe on their mustang? I have a 06 saleen with 8,000 miles. The car has never been in any weather. I was wondering how hard it's going to be to brak the exhaust flange bolts loose?
jbodak31 is offline
Old 11-15-2012, 07:56 AM
MadMike1337
MadMike1337's Avatar
Easy swap. Put the car on jack stands when u do it. Also get a can of Liquid Wrench (avail. At any auto store) and spray the bolts a few times prior to doing the instal.
MadMike1337 is offline
Old 11-15-2012, 04:58 PM
acascianelli
acascianelli's Avatar
I had an catless X-pipe on mine for a while with the stock mufflers. Couldn't stand the sound. Anything below about 3500rpm's and it sounded like somebody was shaking maraca's in the back seat.
The install/uninstall was pretty easy though. It was harder putting the stock H-pipe back on.
acascianelli is offline
Old 11-15-2012, 07:18 PM
Milspec
Milspec's Avatar
I sprayed PB Blaster on the header flange bolts and they broke loose with no problems. The passenger side top header bolt is tricky though, I had to use a U-joint socket with a couple extensions. Also helps if you remove the battery and battery tray.
Milspec is offline
ak98
02-18-2023 08:36 AM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
BrantleyS550
09-14-2015 04:18 PM
wawagner82
09-13-2015 09:02 AM
Quick Reply: Pipes X pipe
