06 Grinding Noise
06 Grinding Noise
I've got an 06 Base Mustang that is making a "dry" grinding noise when I accelerate. Specifically it happens from about 10 mph to about 18 mph. After that it seems to be sound normal.
Weather has been surprisingly warm here, I haven't driven on any dirt roads recently.
I'm planning to take it in this afternoon, but what do you think it could be?
Thanks,
Clueless girl
Thanks,
Clueless girl
Why would you look to add fluid if you don't even KNOW if the tranny is low? Or if it's the tranny to begin with?
We need more info to help you troubleshoot. Is this noise in a particular RPM range? A specific gear or all? At all throttle positions (light, medium and/or WOT)? Only when cold or all operating temps?
Jeez, Nuke, lighten up. OP said she's a Clueless girl.
If there were a dipstick to check the transmission fluid (there isn't) I'd be looking to check the level and the condition of the fluid. Given the speed at which the grinding occurs, it could be that second gear is causing the problem.
Art161, you're correct. I took the car to my mechanic and he confirmed it is the second gear. He doesn't work on automatic transmissions, but contacted another company that does. It could be up to $3,100.
I'm very disappointed in my Mustang. It only has about 68k miles on it. For an 06 I would have expected it to last quite a bit longer.
Sorry, didn't catch the clueless girl thing...
Very few Stang owners have reported tranny problems although it DOES happen. But I'd certainly call around and get a few estimates. $3k sounds quite high.
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
ccdguy
09-19-2015 05:20 PM
