Coyote 5.0 interference engine????
Interference - Piston all the way up, valve all the way down = they make contact
Non Interference - Piston all the way up, valve all the way down = no contact.
That said, I don't know what the 5.0 is, but I'd guess that it IS an interference engine.
My understanding of non-interference engine means that even if the timing chain or belt were to break causing the timing to be off, the valves do not extended far enough down in the combustion chamber to hit the top of the piston.
A 5.0L, 11:1 compression engine, making over 400hp is most likely an interference engine.
I have heard of that now that you explain it... no clue though on the question. Thanks for the answer!
I would imagine that it is an interference engine, but maybe they figured out how to make it not destroy itself when it destroys itself, ford is getting smarter lol
Mainly a concern with engines that have belt cam drives. OHC/DOHC Ford V8's have been chain drive to the cams. Little chance of mis-timing unless there is some significant wear of the guides, tensioners and chains.
Frank
Frank
