2013 GT/CS fog lamp replacement
Hi,
I love my new GT/CS but i hate the difference in color of the fog lamps versus the headlamps ,the fog lamps look yellowish compared to the headlamps, any of you know what replacement fog lamp bulbs ( # number)i can get to obtain a better match ?
I think the Led is only on the standard GT grille lamps, the CS's have halogen bulbs in their fog lights. If you wanted to match the Xenon HID headlamps you would need to install either a LED setup or a HID setup in your fog lamps. If sylvania makes their silver star bulbs that fit you fog lights that would be the easiest way to make them more white but it won't be nearly as good as the LED/HID set ups.
Sorry I don't have any part numbers for you. Your owners manual should have the fog light number and sylvania's site should tell you if they make them.
According the the Owners Manual V6 have H11 hallogen and GT have LED's, So I assume GT are the upper front grill mounted fogs, where the GT/CS would have H11 like the V6 in the lower grill ?
