Sponsored by:
Sponsored by:
Best POWER Adder for the money?
Old 12-29-2012, 11:12 AM
2009 Eleanor
2009 Eleanor's Avatar
Default Best POWER Adder for the money?
Hey guys,
I'm new to this forum and I'm on a budget and would appreciate some advice to a good and reliable power adder. I'm only 16 and just bought a 2009 mustang gt after finishing a restoration and selling my 1972 Dodge Dart. I only can work with about 2500 bucks right now. Let me know what your advice would be and experience with certain power adders. Right now I'm leaning towards a Paxton 1200 tuner kit. Any luck with these? Overheating problems?
Thanks in advance,
Jason
2009 Eleanor is offline
Old 12-29-2012, 12:02 PM
siggyfreud
siggyfreud's Avatar
The tuner kit assumes you have a number of parts that are usually included in the full kit. Unless you have those missing parts, you will still need to spend more to actually use the supercharger setup.
siggyfreud is offline
Old 12-29-2012, 01:33 PM
2009 Eleanor
Do you think it would be safe to buy a used complete kit? Or should I just go with some bolt-ons?
Old 12-29-2012, 01:35 PM
code3GT
Mustang Nazi
code3GT's Avatar
Nitrous
code3GT is offline
Old 12-29-2012, 01:51 PM
moosestang
moosestang's Avatar
If you don't have money to replace the motor, then don't do it!
When I was shopping, the whipple kit was the best bang for the bucks at $5800, because you got reliability, best customer service in the business, gt500 dual fuel pump system, spark plugs, everything necessary to make big power. Now they want a lot more, so I don't know what's the best route today.
A tuner kit means you get no tune, no tuner, no injectors, no spark plugs, no fuel system, basically just the blower and intercooler/heat exchanger. Paxton and vortech both had their fair share of failures when doing a google search. Mostly bearings failing inside the blower. The latest models are probably more reliable. I think paxton now uses a self contained, sealed unit, instead of using engine oil to lube the bearings.
moosestang is offline
Old 12-29-2012, 02:00 PM
2009 Eleanor
Maybe I should just change rear end gears to liven the engine up. My car is an Eleanor clone and badged as a gt500. I want something that will change performance significantly because I feel kinda stupid riding around in a car that's suppose to have 500 hp but only has 300
Old 12-29-2012, 02:54 PM
moosestang
moosestang's Avatar
Well 4.10 gears will livin it up for sure. If my rear end goes out on me, I'm going to replace the whole thing with an frpp boss rear axle for $1400. it's hard to beat that price for a fully assembled beefed up 8.8 with 3.73 gears. Repairing mine would cost about the same for a shop to do it.
if you don't have a CAI and tune, then I would recommend starting there. It's affordable and safe, plus you'll need a tuner to change your gear ratio.
Old 12-29-2012, 02:56 PM
jpplaw
jpplaw's Avatar
Originally Posted by code3GT
Nitrous
Gears and a decent Nitrous system will fit your budget. Just don't go with too big of a shot.
jpplaw is offline
Old 12-29-2012, 03:19 PM
FrostByte
FrostByte's Avatar
Nitrous makes me nervous............. You decide
https://www.google.com/search?q=nitr...ient=firefox-a
FrostByte is offline
Old 12-29-2012, 07:06 PM
2009 Eleanor
After thinking things over and some serious research, I have decided I am going to go with the nitrous. I like the idea of my engine not always being under boost and "purges" are also cool. Thanks for helping me with the decision guys, next post from me will be a video of my car dyno...I'm so excited!!
Quick Reply: Best POWER Adder for the money?
